no chime when turning the key to "run"
Hello, recently I noticed when I turn the keys to run (not all the way to start) there is no chime, (it used to chime 3 times when turning the keys to start) everything else works as normal and the car starts, I am wondering if this is a sign of a bad ignition? I have also been experiencing sometimes I will go to start the car and hear one loud click from the starter but the car does not turn over, take the keys out try again and it will usually crank on the second or third try.
Wondering if these two issues might be related?
thank you
thank you
