negative terminal bolt
anyone know what size the negative terminal bolt is...and if its common enough to find at home depot, or if i would have to go through the dealer to get one. Thanks.
Either will be cheap, I can't see the dealer charging more than 2 dollars for one bolt. Althougth thats probably how much it would cost. I spent 2 bucks for a c-clip for my clutch pedal, was a tiny plastic fitting with 4 prongs, im sure the bolt will be in that range, just get it from the dealer.
Woops, just re-read, I thought he meant the negative bolt that goes to the block near the motor mount.
carguyshu
01-22-2017 11:19 AM
