Need some help with optispark and overheating issues
Old 08-07-2016, 11:38 AM
Maromom's Avatar
94 zip lt1 auto. All stock as far as we know.
We are about to put the 4th optispark in this car in less them 4 months. (One of them went due to the new water pump busting and soaking it)
The car runs excellent for a couple weeks after we replace the opti, and then the nightmare returns. Runs rough, hitches, shuts down while driving eCT.
Does anyone have any ideas why it would be killing these distributor units?
The other question I have is this.
If it idles to long or we drive around town under 30 mph for more then ten mimutes it gets real hot. Not into the red but close. The fans are working the t Stat is new as well as the water pump. Any suggestions?
Thanks I'm advance for any help
Maromom is offline
Old 08-07-2016, 04:57 PM
Re: Need some help with optispark and overheating issues
What brand Optispark are you buying?
Have you examined the failed units to see what part is failing? Have you scanned it for codes when the problems start? The key fatal code for the Opti cam position sensor failure, DTC 16, does not turn on the SES light.
Injuneer is offline
Old 08-08-2016, 05:11 PM
cheapchevy's Avatar
Had similar problem once, but mine went into red. When you changed the water pump, did you follow the factory bleeding procedure using the water bleed screws? I had forgot to bleed the system correctly, and got an air pocket in the driver side cylinder head. The instrument panel temp gauge reads the temp from a sensor in that cylinder head. But the PCM reads coolant temp from a sensor on the water pump. Once I bled the system correctly - problem solved. Hope this helps.
cheapchevy is offline
Old 08-17-2016, 06:35 PM
Maromom's Avatar
We did use the proper bleeding system. A couple times now just to be sure
Maromom is offline
Old 08-17-2016, 06:37 PM
Maromom's Avatar
We've used a few different brands now, advanced auto car quest and eBay cheap. Another car quest in it now and no they haven't been examined to my knowledge
Maromom is offline
Old 08-17-2016, 08:23 PM
Have you had DTC 16 for any of the failed units?
Injuneer is offline
Z28Freak86
07-12-2015 01:35 PM
blkcamaro_z28
06-25-2015 12:07 AM
jwade88
06-14-2015 09:38 PM
jmadoll
06-10-2015 04:41 PM
95_Z28/SS
05-20-2015 01:23 PM
Quick Reply: Need some help with optispark and overheating issues
