Need some help identifying these parts?... - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 08-14-2013, 07:42 PM   #1
Stephen68's Avatar
Hello, let me start by telling a little about my problems. i have had this car about 3 weeks now. i just recently had a chance to start going through it and trying to bring life back into it. upon removing part of the dash and lower dash panels, i have noticed that some of the electronics have either been modified or botched up. this all came after noticing that my passenger side power window switch would not hardly work. my dome light will not work either as well as my radio, reading lights on the rear mirror, keyless entry and alarm. i also have no dinging when the key is in the ignition or the lights left on. i figured i would try and run down some of the wiring under the dash and need some help identifying several components and wires. i took pictures that i think will show what i am concerned about.....
Stephen68 is offline   Reply With Quote
Old 08-15-2013, 10:39 AM   #2
Re: Need some help identifying these parts?...
Are you good at electrical schematics and wiring.. what I would suggest is download the free service manuals or purchase a GM set of service manuals. Start with one problem and try to fix it. To me repairing under dash wiring is a tedious and time consuming process. Your first pic looks like a Theft Deterrent relay bypass, from pic it looks incorrect. If it's what I think, your car will start in gear with that yellow jumped to purple. Does it ?? Correct way would be to tie smaller yellow/black to a ground (allows relay pick w/o VAT's key) . ref page 8A-30-0 of service manual
bobdec is offline   Reply With Quote
Old 08-15-2013, 11:47 AM   #3
Stephen68's Avatar
Quote:
Thanks bobdec for the reply. as far as my car starting in gear i havent tried it but will. what is the purpose of this by pass if that is what it is?
Old 08-15-2013, 04:59 PM   #4
The TDR is one piece of bypassing the VAT's (security). The TDR blocks the starter activation if key is incorrect. Looks like you have yellow tied to purple that bypasses the TDR. ref this schematic from shobox.com a very good site to know.. http://shbox.com/1/pass_key.jpg . By the way those yellow connectors are usually air bad circuits, they use yellow to warn against possible accidental bag activation.
Old 08-15-2013, 05:38 PM   #5
Stephen68's Avatar
Thanks bobdec, i removed the jumper from the relay and now my car will not start....how is the correct way to fix this? i know i can put the jumper back on it but im sure thats not the correct way lol....Thanks again!
Old 08-15-2013, 06:25 PM   #6
Stephen68's Avatar
i put the jumper back on it to get it running until i can replace the ignition key with a new one. Will this security system prevent my stereo from working? i have tried everything i can think of and it will not get power to the head unit.
Reply
Thread Thread Starter Forum Replies Last Post
6.2 ls3 parts and LS3 cnc heads BIGCOWL-IMP Parts For Sale 0 12-19-2014 07:59 AM
Need brake pads that will hold the car at 2000 RPM staged... Redbird Drag Racing Technique 3 09-14-2002 10:18 AM
Pics of the test car I saw in South Padre Island, Tx: Sixer-Bird Automotive News / Industry / Future Vehicle Discussion 34 08-31-2002 01:59 PM
Using bald street tires as slicks... Redbird Drag Racing Technique 12 07-20-2002 07:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
