Need help with my 94 z28
Old 06-04-2015, 09:21 PM
doza's z28's Avatar
I turn it on and it's sounds like it's cammed idk what the problem is?
doza's z28 is offline
Old 06-04-2015, 10:38 PM
Fatdog2's Avatar
Re: Need help with my 94 z28
Did you get any codes?
Fatdog2 is offline
Old 06-04-2015, 10:47 PM
doza's z28's Avatar
codes where?
Old 06-04-2015, 11:22 PM
doza's z28's Avatar
codes where at?
Old 06-04-2015, 11:28 PM
Did you scan the PCM (computer) for diagnostic codes?
Injuneer is online now
Old 06-04-2015, 11:34 PM
doza's z28's Avatar
naw I haven't,
Old 06-05-2015, 09:52 AM
OK... not much to work with here.
Describe the problem more fully. When does it sound like it's "cammed" - at idle, under heavy acceleration, normal cruising, all the time? Do you mean is has an unstable idle, misfires, etc.? Does the exhaust smell or fuel?
Old 06-05-2015, 11:34 AM
doza's z28's Avatar
like when I turn it on it's sounds cammed, and the longer I leave it on it starts to idle, and wanting to turn off' I press the gas and goes quiet for a lil then accelerates.
Old 06-05-2015, 12:26 PM
Do you mean as the engine warms up it starts to idle more smoothly?
What EXACTLY do you mean by "sounds cammed"? Do you mean it is a very rough idle... it surges, it lopes?
You have to explain the problem clearly, or there's no way to help you.
Old 06-05-2015, 12:30 PM
doza's z28's Avatar
cammed by it wants to turn off' like it idles even more roughly after it warms up
Old 06-05-2015, 12:43 PM
doza's z28's Avatar
it's loops
Old 06-05-2015, 01:44 PM
How old are the:
-spark plugs?
-spark plug wires?
-O2 sensors?
Does it ever actually stall?
Rough idle can be caused by a faulty EGR valve, failing to close fully.
Is the SES light on?
Has the engine been modified in any way? How many miles on the engine?
F'n1996Z28SS
08-23-2023 11:19 PM
Renegade Toker
01-23-2015 10:27 PM
NewsBot
01-11-2015 06:10 PM
01-05-2015 07:14 PM
cmdeshon
01-04-2015 11:15 AM
Quick Reply: Need help with my 94 z28
