Need Help with cam swap!
Old 11-23-2014, 04:21 PM
Noenav's Avatar
So I rebuilt my engine two months ago and I installed an advanced induction cam in it but I think it is out of time because I have a very bad no start condition. There is gas and spark I checked already and when it fires up it pings and sometimes when it doesn't start it shots smoke out the intake. My question how to get the timing right on an aftermarket cam? When I installed it all I did was align the two dots together the one on the cam gear and crank gear did I do it right?
Noenav is offline
Old 11-23-2014, 05:42 PM
Re: Need Help with cam swap!
Lt1?
Injuneer is offline
Old 11-23-2014, 06:00 PM
Noenav's Avatar
Yes
Noenav is offline
Old 11-23-2014, 07:11 PM
Year?
You really need a "Signature".
If you got the cam aligned correctly, did you index the Opti correctly?
Injuneer is offline
Old 11-30-2014, 12:23 PM
Noenav's Avatar
I'll add one as soon as I can. What do you mean by index the opti correctly
Noenav is offline
Old 11-30-2014, 05:44 PM
How to index the Opti depends on the year of the car. But you appear to not want to provide that info. See why it's important to have that info up front?
Injuneer is offline
Old 12-02-2014, 07:22 PM
Noenav's Avatar
sorry I'm just not very good with this but i think i updated it now but just in case i didn't ill post it here.
1994 z28 lt1 A4 Aluminum driveshaft
4:10 gears with moser cap
Hooker headers
Advanced induction cam which is a custom grind with matched beehive springs and titanium retainers.
Ported intake to take a 58mm tb
Msd wire,cool and multiple spark
3800 stall
slightly ported heads
a/c and egr delete
untuned
Noenav is offline
Old 12-02-2014, 07:23 PM
Noenav's Avatar
also it threw an injector circuit code could that be the problem?
Noenav is offline
Old 12-03-2014, 09:46 AM
Always give the exact code number.
Splined drive opti indexing
shoebox is offline
Old 12-04-2014, 03:25 PM
Noenav's Avatar
Sorry I don't know the exact code I lost it in my old phone but the opti was indexed properly I'm just stuck as to what it can be because I've pulled the spark plugs and there's a lot of spark. What I did notice after I tried to start it was a lot of fuel on the speak plug as if it's flooded. The car had been working fine I even took it to the track and ran a 12.8 so I'm so confused as to what it can be. Could the valves be adjusted wrongly?
Noenav is offline
Old 12-04-2014, 05:06 PM
It ran fine AFTER the cam install? Or only BEFORE the cam install?
If the Opti is not indexed correctly to the cam there will be lots of spark but it will be at the wrong time.... out of time, exactly as you indicated you thought the problem was in your first post.
I've been on this site for 16 years now, and you would not believe the number of people who have "sworn" they installed the Opti correctly, only to find out after pulling it off, that they indexed it wrong.
Are you sure you got the dots correct on the timing gears.... per the guidelines on Shoebox's site?
What brand is the Opti, and is it possible the rotor screws have come loose - very common problem? That would cause the spark to be out of time.
The only code for an injector fault is DTC 18.... does that ring a bell?
Yes, if the valves are not adjusted correctly, you could have combustion backing into the intake manifold or blowing out of the exhaust.
Injuneer is offline
Old 12-05-2014, 08:42 PM
Noenav's Avatar
well it never really ran perfectly but it did fire up and ran ok for a good month.
well i think i did all those things correctly but this is my first lt1 rebuild so not sure. i think i might just take it to a good mechanic soon i give up on it.
the opti it has is a chandler motorsport from ebay.
yes it is shooting combustion back into the intake idk i might just take it apart again thanks for the help i really appreciate it!
Noenav is offline
Old 12-05-2014, 08:46 PM
Noenav's Avatar
i also forgot to add that once the car was starting to go out it would sputter really bad when i would floor the accel fast or quick as if it wanted to turn off and backfired. but once i let it go it would idle fine. if i pressed the accel at a constant pace it wouldn't sputter only when i would floor it quick or all of a sudden.
Noenav is offline
Old 12-05-2014, 09:54 PM
Not saying this is your issue, but Chandler optis don't enjoy the best reputation.
shoebox is offline
Old 12-06-2014, 07:35 PM
If it started and ran a 12.8 AFTER you installed the Opti, it's indexed correctly, and the timing gears are installed correctly. The Chandler unit may just be dying it's usual premature death.
Injuneer is offline
Klypto
03-23-2016 09:05 AM
jj_burchiel
03-05-2015 07:05 AM
chuyz28
02-19-2015 12:50 AM
chuyz28
01-15-2015 04:14 PM
chuyz28
11-25-2014 11:14 PM
Quick Reply: Need Help with cam swap!
