CamaroZ28.Com Message Board
CamaroZ28.Com Message Board (http://www.camaroz28.com/forums/)
-   General 1967-2002 F-Body Tech (http://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/)
-   -   Mystery problem solved: VATS causing a no-start condition. (http://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/mystery-problem-solved-vats-causing-no-start-condition-879903/)
97Z28Muscle 06-28-2014 01:39 PM
I have been having this problem with my '97 Z28 for a year and a half. You would be driving along, cruise control set and the ignition would die, come alive, die, come alive and so on, very intermittently. Couldn't pinpoint the cause until the car left me stranded in a parking lot, almost. Wouldn't even crank so I figured maybe the starter was going bad. We push started it and it just stumbled and backfired, no start. Messed around with the key for 15 minutes and finally got it to start. So the research began...I read a lot of posts where people had a bad key, dirty key or ignition, etc. So I cleaned mine and also replaced the key with a brand new one. Still, the car would not crank, whatsoever. I went online again and found out people are bypassing their VATS, or vehicle anti theft system, or pass key II. It is a little resistor I bought from a reputable online dealer(google "bypass module" and you will find it). Took me 10 minutes to wire it in and the car has not caused me a single problem since. It fires up every single time, and the intermittent ignition is all overwith, finally. Only downside is now the anti theft is disabled, but my car isn't worth more than $5k anyways so who cares.
SA68SS 06-28-2014 01:47 PM
Re: Mystery problem solved: VATS causing a no-start condition.
Good to know. thanks for posting.
Is the resistor set in the ignition switch area, or in the engine bay?
97Z28Muscle 06-28-2014 02:22 PM
The resistor is wired in at the bottom of the steering column. All you have to do is take off the access panel and look for the correct wire. Cut it, install resistor, problem solved. It literally takes 10 minutes and no skill. The resistor I purchased came with instructions and pictures.
SA68SS 06-28-2014 03:56 PM
Quote:
Cool! Thanks for the info.
Injuneer 06-28-2014 08:03 PM
The PASS-Key bypass info/diagram has been on Shoebox's site for about 15 years.....
4th Gen LT1 F-Body Tech-PassKey/VATS
4th Gen LT1 F-body Tech Articles
http://shbox.com/1/vats_bypass.jpg
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
