Missing, hesitation, limp mode tranny, everything messing up - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 04-15-2014, 05:35 AM   #1
lt1redmonster's Avatar
Unhappy Missing, hesitation, limp mode tranny, everything messing up
I have a 95 z28 with the auto tranny. Recently it has been developing severe symptoms. It started out when I tried to start it yesterday. It took a lot longer to start than it usually does, and it kept stalling unless I coaxes the throttle to keep the rpms high. Eventually I got it to idle, but idled really rough. I don't have a cam or any internal engine mods. Then later, I took it for a drive to see how it drove, and it would jerk from hesitating every few seconds, similar to the way it feels when you are about to run out of gas. At the same time,my speedometer went erratic and started reading crazy reading and skipping around, which then put my tranny into limp mode, and took out 4th and first gear. Between the car jerking and my tranny, I barely made it home.
I have checked fuel pressure, looks fine, reading between 42-50.
I recently replaced the spark plugs, fuel filter, and cleaned MAF sensor. I unplugged the MAF sensor to see if it would make any difference, and it didn't. I'm not sure where to go from here... I would appreciate any suggestions or help.. This is my daily driver and only car, so it's quite crippling at the moment. I can't scan for codes cause I don't have the right cable..
lt1redmonster is offline   Reply With Quote
Old 04-15-2014, 06:21 AM   #2
Super Moderator
Re: Missing, hesitation, limp mode tranny, everything messing up
Read this, and consider downloading the software and building or buying the correct cable:
http://www.camaroz28.com/forums/comp...95-lt1-874306/
Your fuel pressures are higher than normal, and exceed the GM specification, for 47psi max with the vacuum compensation line off the fuel pressure regulator. Did you measure the pressure with or without the vacuum line connected.
Is the SES light on?
Injuneer is offline   Reply With Quote
Old 04-15-2014, 02:29 PM   #3
I checked the pressure again, and my first quote is a little high actually, the pressure isn't quite that high, it's about 37-45 with the line disconnected. I have that program, and I'm planning on buying the cable as soon as I can. I didn't notice any lights coming on.
Old 04-15-2014, 03:40 PM   #4
Super Moderator
Pressure at idle, vacuum line off should be a STEADY 43.5psi. GM accepts anything in the range of 41-47psi. The pressure should only drop below that value when you reconnect the vacuum line, and the regulator drops the pressure proportional to intake manifold vacuum, about an 8psi drop with a stock cam.
When the speedo went crazy, did you notice if the dash volt meter had dropped near the red area?
The PCM monitors the transmission, and will set codes for transmission faults, and those codes do not turn on the SES light. The fault code for the vehicle speed sensor (VSS) does not turn it on.
Old 04-15-2014, 03:59 PM   #5
Well, for one thing, I'm not sure if my ses light even works, cause it's always off, even when you first turn the key,. I unfortunately did not notice the voltmeter on the dash,. I'm pretty sure my fuel pressure is good, it seems to be at least.
Reply
Thread Thread Starter Forum Replies Last Post
Exhaust now dragging on ground. Need some advice. Noct General 1967-2002 F-Body Tech 3 05-26-2016 11:26 AM
Lt1 has me stumped. missing and popping Z28Freak86 LT1 Based Engine Tech 14 07-12-2015 02:35 PM
1993 Z28 hesitation problem jocamino LT1 Based Engine Tech 13 05-14-2015 08:37 AM
Selling my 1995 3.4 V6, $1200 Snoman73 Cars For Sale 0 11-17-2014 08:22 PM
Need urgent help from a west sider! Timberwolf Midwest 12 08-18-2002 08:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
