CamaroZ28.Com Message Board
CamaroZ28.Com Message Board (http://www.camaroz28.com/forums/)
-   General 1967-2002 F-Body Tech (http://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/)
-   -   Low coolant???? (http://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/low-coolant-874341/)
TaskForce141 06-17-2013 04:23 PM
Low coolant????
my 94 Z low coolant light keeps coming on but i had it checked out and the coolant is within the marks, car runs hot, stays real close to the red line. anyone know whats going on here??
Injuneer 06-17-2013 04:32 PM
Re: Low coolant????
Sounds like you are checking the level in the coolant reservoir ("between the marks"). You have to check the coolant level in the radiator, since the level sensor in on the passenger side radiator end tank, engine side, a couple inches below the fill cap.
The level in the radiator has to be right up to the very top. Any air in the system will reduce the system cooling capacity.
If you find the radiator is full, and the "low coolant" light is still on, the level sensor is a common failure part. The coolant seeps into the printed circuit board and corrodes it. The sensor can be replaced, or you can unplug the harness, which will turn the dash light out.
TaskForce141 06-17-2013 05:24 PM
Re: Low coolant????
Thanks man im going to check now, your awesome. i love this site, glad i found it.
TaskForce141 06-17-2013 05:38 PM
Re: Low coolant????
so i checked it and the fluid is still to the top, so will it hurt to keep driving it with the low coolant light still coming on until i can replace the sensor? i dunno where the wire is to unhook it. im very green when it comes to tinkering under the hood my friend.
moparman 06-17-2013 07:26 PM
Re: Low coolant????
No, it won't hurt it. The sensor is by the battery, on the side of the radiator.
TaskForce141 06-17-2013 08:12 PM
Re: Low coolant????
Right on thanks guys. I gotta another question concerning my thermostat. First I dont know where its located, I just wanna check it out to see if its an aftermarket 160 degree thermostat. When I find it how would i know ? When I got the car the programmer chip was set on a 160 and Im just wanting to verify that.
moparman 06-17-2013 09:35 PM
Re: Low coolant????
You need to bookmark this site: 4th Gen LT1 F-Body Tech Aids
It's one of the sites you'll use. Shoebox has the lowdown on thermostats on that site.
TaskForce141 06-17-2013 11:01 PM
Re: Low coolant????
moparman 2 seconds on that site you mentioned and i found where my thermostat is located. lol. thanks man. i will def bookmark that site so i can refer to it later because i know im gonna find something else to be hung up on. thermostat doesnt look too complicated too check on now as it did before.
moparman 06-18-2013 07:42 AM
Re: Low coolant????
Take notice that the LT1 has it's own specific thermostat. The standard small block Chevy 'stat does not perform properly in the LT1.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
