Left turn signal blinks slowly ?? - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 07-16-2013, 09:47 PM   #1
978Racing's Avatar
2000 car has Left turn signal blinking slowly, the right one is OK. Any help would be greatly appreciated? Thanks
978Racing is offline   Reply With Quote
Old 07-17-2013, 11:08 PM   #2
Member
GaryDoug's Avatar
Re: Left turn signal blinks slowly ??
Any time one side blinks slower, it means there is not enough current flowing on that side. That can be caused by several things, burnt out bulbs (most common, check them all), bad socket connections, defective turn signal switch, DRL module. First make sure all the lamps are coming on that should light. Compare with the good side. There are two turn lamps for each side on the back, make sure both are coming on. Look for lamps that appear dimmer than the same one on the other side.
Don't be fooled by replacing the flasher and then seeing that it apparently works, Many newer flashers are not affected by the loss of current and will mask the problem.
GaryDoug is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
want to replace stock speakers, can it be done? stangspank Car Audio and Electronics 3 11-13-2015 02:02 PM
odds and ends CaRParts102 Parts For Sale 0 12-06-2014 09:45 AM
which wires? vinnyxgunz Car Audio and Electronics 5 08-28-2002 10:41 PM
C6 Corvette mule spotted! Darth Xed Automotive News / Industry / Future Vehicle Discussion 13 07-22-2002 01:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
