left sde brake skids
hey guys, I got a problem with my brakes. the other day I was driving and someone cut me off, and i slammed the brakes.and the car did a fish tale. and the abs sensor light came on then shut off.. the left front side brake skids.so I went in a parking lot o test it again. and it does just that.. anyone know what could be causing this..i appreciate the info
Re: left sde brake skids
That means the ABS system activated, but for some reason it could not prevent the left front brake from locking up. Were you on a hard surface or gravel at the time? Sounds like the caliper may be sticking, preventing the pressure reduction by the ABS motor from eliminating the lockup.
I would examine the front brakes for wear, noting any difference between the pad thickness, and rotor wear between the left and right brakes. A sticking caliper is going to increase pad wear.
I was on a hard surface.. regular street no gravel or rain or sand. I will check the caliper. it does look like the wheel has been covered in a lot of brake dust lately, whats a goodway to tell if the caliper is good or bad ?
Louey
Pacific
07-21-2015 10:06 PM
