Leaded fuel
Location: Somewhere between a shotgun barrel, and a blood spatter on the wall.
Leaded fuel
i know "unleaded fuel only"
but why?
i've heard something about that you shouldn't use leaded gas with a car that has cats... because it will clog them
is there any other reason?
i've noticed a consistant gain at the track by letting my tank get really low and mixxing a few gallons of race gas with the gallon or two of the 93 thats left.
i have gutted cats
is there any other reason i shouldn't put leaded race gas in my car? its only a few gallons once a week...
thanks
Jared
but why?
i have gutted cats
thanks
Jared
Re: Leaded fuel
Unleaded race gas is fine.
If you have already mixed leaded gas with your fuel, you have ruined your O2 sensors.
The lead destroys the O2 sensors and will cause your fuel injection system to fail to work properly.
My guess is that on an 2002 you have 4 O2 sensors at about $40.00 each. A few gallons of leaded fuel may have cost you $160.00.
This is not a wise thing to do.
Stop doing this or you will cost yourself some repairs for sure.
Z28
Z28
Re: Leaded fuel
Z28
Z28
Re: Leaded fuel
IF you had cats it would kill them too. Leaded fuel also leaves deposits. Thats why cars started running hardened valve seats when unleaded became manditory.
Chances are, with the few mods you have, the gains are seen because you have a lean condition and you're picking up some detonation and therefore some knock retard. The ONLY thing higher octane does for you is not detonate as easily as lower octane fuel. Higher octane gasoline DOES NOT burn hotter, cleaner or create more power. It just takes more heat/energy to ignite.
Re: Leaded fuel
i know what higher octane does...
and it does help
but my car is not running lean
i am using unleaded 101
i was just hoping i could start using leaded 110 so i could use less of it (its pricy)
so just one use can mess up your o2's huh?
Re: Leaded fuel
I spoke with an engineer at Bosch in California this past spring and he said their O2's will last at least 100 driving hours using leaded fuel. I would think mixed like that it would be much longer.
Re: Leaded fuel
and it does help
and it does help
And yes, the O2's may LAST a certain amount of hours running leaded fuel, but will they perform as well as they should after running 1 tank of leaded fuel?
Re: Leaded fuel
you don't have to have a screwed up engine to benefit from higher octane fuel if you have an even somewhat high compression engine... stock.
Re: Leaded fuel
and it does help
and it does help
Race fuel comes in many flavors. Different fuels have varying specific gravity numbers. Depending on the race fuel and pump gas you run the afr mixture can vary because of the density of the fuel. This can affect how the car runs at the track.
Track fuel isn't going to hurt your injectors or any other kind of voodoo assuming its good clean fuel like it should be.
Race fuel also can be more stable than pump gasoline and the car may idle smoother and run a bit better at high rpm.
Running fuel with an excessive octane number, such as 110 on a stock motor will likely result in a power loss as you just don't have the compression to make use of it. The fuel can burn slower in that case and cause your pressure peak to occur at the wrong time and be lower over all.
Re: Leaded fuel
yes,
i haven't used leaded fuel, like i said i have been using unleaded 101
i wasn't planning on running straight 110
i thinking i could dillute 1 gallon of 110 with 2-3 gallons of 93 in a mix.
but i won't now anyway..
i'll just let my tank get down really low... (to like a gallon or so) and add a couple gallons of 101
i keep my tank low for track events anyway for weight
Re: Leaded fuel
Even with all this, what are you picking up? MAYBE .1 sec tops? More likely half that.
Re: Leaded fuel
.15
which could be the difference between a 13 et and a 12
Re: Leaded fuel
Also, keep in mind that if you are running 2 gallons of 93 and 2 gallons of 101, you only have 97 octane.
First of all, your car won't benefit much (if at all) from it. If you're running an engine with forced induction, this can allow you to run more boost without detonation.
FWIW, I wrote up a article awhile ago on Toulene vs Xylene vs MTBE (MethylTertiaryButylEther) vs Methanol vs Tertiary Butyl Alcohol if you'd like to read up on octane boosters. They all pretty much have a R+M/2 of around 112-117 (with the exception of alcohol and methanol which are around 100-102)
