K&N oil filters?
Old 04-24-2004, 11:56 AM
StealthZ28's Avatar
K&N oil filters?
Are they worth the extra dough? What are the advantages? <if any>
StealthZ28 is offline
Old 04-24-2004, 02:36 PM
94blackz14.2's Avatar
I wouldn't get just the air filter. It alone isn't worth the money, because the rest of the air induction isn't any good. Save a little bit more and pick up a Cold Air Induction kit. Then you'll feel a difference.
94blackz14.2 is offline
Old 04-24-2004, 03:10 PM
BarnesGN's Avatar
Oil filters are made to meet certain tolerances and the K&N is about as strict it gets.
But I would say that they are overpriced, try using either a pure one purlator or a mobil 1 filter.
BarnesGN is offline
Old 04-24-2004, 04:17 PM
VegasZ's Avatar
Ive been using their oil filter for a while now. It is made out of thicker metal than the delco one. This gives you extra protection from being punctured by road debri.
VegasZ is offline
Old 04-24-2004, 07:19 PM
magman's Avatar
something to think about. GM will no longer honer warrantys on cars that have a senser (maf or map) if they fail if the car has a "Oil soak" filter on it.
magman is offline
Old 04-24-2004, 07:21 PM
Pandamonkey's Avatar
No kidding?
When did this happen?
Pandamonkey is offline
Old 04-24-2004, 07:33 PM
Eliminator's Avatar
I seen the tests for K&N filters vs reg. and they breath better. But if your gonna spend the money save for a whole kit CAI.
Eliminator is offline
Old 04-24-2004, 07:40 PM
eagleknight97's Avatar
Ok, you guys are confusing a the OIL filter with a Oiled AIR filter. Two completely different things. And yes, I believe that they are worth it. Ask Patman.
eagleknight97 is offline
Old 04-24-2004, 09:43 PM
ABA383's Avatar
I've been using the 3002 for a while now...imho its worth it just for the 1" nut on the bottom...way easy removal....
--Alan
ABA383 is offline
Old 04-24-2004, 11:10 PM
Sorry about that, I thought you were talking about the air filter.
Old 04-25-2004, 02:00 AM
jdhommert's Avatar
I think its worth it for that nut too. And the fact that it is a great oil filter and its strong doesn't hurt either.
Here's a little story to make you think about getting one.
I got my car, and changed the oil shortly after. The assclown at whoever tightened it way to much,and i just couldn't get the filter off. I was under my car, and put all i had into it, and finally put so much pressure on it with the oil filter wrech, that the whole filter COLLAPSED
I called my dad freaking out, he said get a bigass screwdriver, jam it through,and turn. Simple enough, right? So i find a massive screwdriver that is at least a foot long. Stick it through, and turn. Guess what happens? If you guessed the filter started to tear, instad of loosening,your correct .
So he came over, and we both got under my car,and we eventuall had the filter torn apart down to right below the gasket,and we tried to kind of hammer it off, by sticking a screwdriver/chisel in one of the holes and hitting that to try to get it to break loose.
No luck
Started changing the oil at ~430pm. We both crawled out from under my car at 2am or so. Reason we crawled out,was because we were just gonna have it towed to a shop where they have a lift.
It took them over an hour to get it off.And these are ASE certified mechanics.
All that,just from overtightnening a very,very,very poorly made oil filter.
Fram=major,major,major suck.
I knew right then that i was DEFINATLEY getting a K&N next oil change,just for that nut.
jdhommert is offline
Old 04-25-2004, 03:05 AM
Dave88LX's Avatar
What is this nut that you speak of?
Dave88LX is offline
Old 04-25-2004, 03:12 AM
jdhommert's Avatar
Smile
http://knfilters.com/oilfilter.htm
Old 04-25-2004, 01:04 PM
MysticTeal 95 V6's Avatar
You can catch their filters on sale at Advance on occasion... I picked mine up last month for $9.
MysticTeal 95 V6 is offline
Old 04-26-2004, 09:28 PM
Red96Lt1's Avatar
They also don't have the stupid cardboard end cap on the inside that fram and other crappy filters do. FRAM SUCKS!
Red96Lt1 is offline
Quick Reply: K&N oil filters?
