Ignition Wire separators - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 02-20-2014, 03:59 PM   #1
Hi everyone!
Just a quick question. Im looking to do a plug and wire job and have the 8.5 mm MSD wires. I wanted it to look pretty nice under there, and was wondering how many of those wire separators I would need to get for the job.
Thanks in advance!
mmf_1013 is offline   Reply With Quote
Old 02-20-2014, 05:45 PM   #2
Super Moderator
Re: Ignition Wire separators
Will you be routing the wires in the stock configuration - under the manifolds (very tight in the bracket on the front of the engine, and through the PS pump support), or will you using an "over the valve cover" setup with headers, of some other aftermarket approach?
Injuneer is offline   Reply With Quote
Old 02-20-2014, 09:35 PM   #3
I will probably going in the stock configuration, as I still have the manifolds.
(hope to get headers maybe next year )
Old 02-22-2014, 11:41 AM   #4
Super Moderator
The wires will be "trapped" until they turn the corners to the sides of the engine. At that point, a 4-wire separator, and two 2-wire separators should be adequate for each side. That assumes you are not using the stock metal bracket/cover on the drivers side that holds the wire for #7 againast the head. If the wires have been changed previsouly, that cover often gets discarded, because it is difficult (but not impossible) to reinstall.
Courtesy of Shoebox:
http://shbox.com/1/opti.jpg
On my engine (bought the car new) the wire for #7 was tucked under the exhaust manifold with the cover, and did not wrap around the manifold as shown in the cut, above, from the factory manual.
Old 02-25-2014, 02:57 PM   #5
awesome, thanks for the help!!
Wish me luck as I have read they can be a pain!
Old 02-25-2014, 05:53 PM   #6
Super Moderator
Quote:
Just remember... lay in an adequate supply of band-aids and cold brew!
Reply
Thread Thread Starter Forum Replies Last Post
Project Frankenbird - spring 2015 - D1SC 383 Lt4, advice welcome! LONG dbusch22 Forced Induction 6 10-31-2016 12:09 PM
Battery Bad, Dead Cells. Radio shuts off, etc eanhl2004 General 1967-2002 F-Body Tech 6 04-04-2015 01:01 PM
Delteq Ignition system Ari G Parts For Sale 0 12-11-2014 04:21 PM
Wiring the CSI, quick questions, i've read the archives... lbrowne LT1 Based Engine Tech 25 11-13-2011 05:25 PM
Which 6.75" 2 or 3 way speaker is good & reasonably priced? Wilson Car Audio and Electronics 0 07-21-2002 06:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
