Ignition kill switch or fuel pump cut off switch for security?
Old 04-23-2010, 08:28 AM
Mikes 1994 z28's Avatar
Has anyone hooked up an ignition kill switch or fuel pump cut off switch before? I’m looking to do this mostly for added security. Which one would be easier or better to rig up a switch to? Where would it be easiest to tap into the starter ignition switch or fuel pump wiring?
Mikes 1994 z28 is offline
Old 04-25-2010, 11:31 AM
DeuceGI's Avatar
A super simple way to achieve the same result would be to pull the fuse in either circuit. You could also replace the fuse with a blown fuse of the same amperage/color so nothing is obviously amiss. On my Z24 i pulled the fuse for the fuel pump. It got broken into but never stolen. YMMV
DeuceGI is offline
Old 04-25-2010, 08:15 PM
You know the engine won't run without the low res pulse signal from the Opti. Simple switch in that wire.
Injuneer is offline
Old 04-25-2010, 08:40 PM
Good ideas. Thanks guys.
10-31-2016 11:09 AM
Scottyboy
02-11-2015 10:28 PM
97Z28Muscle
02-06-2015 10:44 PM
RiverMutant96
01-30-2015 09:21 AM
ANDYZ28
12-29-2014 09:13 PM
Quick Reply: Ignition kill switch or fuel pump cut off switch for security?
