ignition control module testing
Old 05-05-2015, 11:33 AM
rick350's Avatar
my 97 z28 keeps stalling. this happens when driving or with car stopped. car starts right back up. if I use car then let it sit for 20 mins. or more it will not fire. so, something is soaking up heat and is not liking it. I am thinking it is the icm, how do I test this part?
rick350 is offline
Old 05-05-2015, 01:09 PM
Re: ignition control module testing
Have you scanned it for codes?
Take the ICM to an auto parts store, have it tested. Make sure they understand it has to be heated up to test issues with heat soak.
Injuneer is offline
Old 05-05-2015, 01:15 PM
rick350's Avatar
yes, I did scan for codes. none. about year and a half ago replaced opti,wires,plugs,coil, has no vacuum leaks, and is getting fuel. car has 86,000 miles
rick350 is offline
Old 05-05-2015, 03:39 PM
An open circuit or a short in the ICM should set codes. But have it tested.
Consider this:
http://shbox.com/1/4th_gen_tech2.html#ICM_cooling
Injuneer is offline
Old 05-05-2015, 05:03 PM
rick350's Avatar
thanks fred!
rick350 is offline
LingenfelterZ28
04-25-2015 10:24 PM
ad356
04-11-2015 10:30 PM
dluna333
15
03-13-2015 12:30 PM
dluna333
Parts Wanted
03-06-2015 07:11 AM
Cam28_boy
08-06-2002 08:40 AM
Quick Reply: ignition control module testing
