CamaroZ28.Com Message Board
CamaroZ28.Com Message Board (http://www.camaroz28.com/forums/)
-   General 1967-2002 F-Body Tech (http://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/)
-   -   How would be the easiest way to ...... (http://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/how-would-easiest-way-875877/)
Stephen68 09-12-2013 12:20 AM
hey everyone, can one of you more experienced guys or gals recommend to me the easiest approach to replacing my motor compartment wiring harness? i am tired of running into one problem after another where someone has hacked and whacked mine up., so i figure it may be easier to just replace the darn thing. Is this a feasible option or is it too big of a job and hassle? Also, where would i or how would i cut or splice into the harness for best results? When i buy a wiring harness, is it necessary to buy the ECM also or will mine work? Any help is appreciated guys. the previous owner attempted to install a key less entry system and there are plugs and wires missing all throughout my harness and honestly i don't trust it.
Thanks!...:think:
Jeffs1997 09-12-2013 12:25 AM
Re: How would be the easiest way to ......
Quote:
Thanks!...:think:
It is easy to replace on both 3.8 and 5.7 ...
Stephen68 09-12-2013 12:38 AM
Quote:
Really Jeff, is there a central plugin or does it need to be cut and re spliced in?
Thanks!
Jeffs1997 09-12-2013 09:07 AM
Quote:
Thanks!
Are you talking the pcm harness or lighting harness? what year and engine do you have?
Stephen68 09-12-2013 05:33 PM
Quote:
PCM harness. i have a 1994 LT-1 IN my Z28
shoebox 09-12-2013 11:45 PM
Your PCM harness is going to look like this and it is just a matter of plugging it all in.
Now, if your interior harness is hacked up from poor attempts at wiring in aftermarket alarms and keyless entry items, it won't do anything for that, because it has nothing to do with the engine harness.
Stephen68 09-14-2013 07:11 PM
Thanks shoebox, now if i can just find the harness lol....:cry:
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
