Low voltage
Old 05-27-2012, 01:07 AM
my1994z28's Avatar
Low voltage
I relocated my battery to the back of the car on my 94 z28.I used the correct gauge battery cables,I had the 140amp alternator tested off the car and it passed with no problems..I have a new optima red top battery,had it tested and it passed..Up at the alternator with my volt meter its putting out 14.1 volts,back at the battery with the volt meter I am getting 13.65 volts..My scanmaster is only reading 13.10 volts,also the stock volt meter in the car is reading 1/2 way..Does this sound like a bad ground problem?or do i need a bigger alternator?While driving the volts get no higher than 13.30..Any suggestions is appreciated..
my1994z28 is offline
Old 05-27-2012, 06:59 AM
bw_hunter's Avatar
Re: Low voltage
By correct size battery cables, do you mean stock sized?
Voltage drop is a function of length and resistance. If you keep the same gauge wire, you'll see lower voltage. Reduce the resistance by going to a smaller gauge number (larger diameter) wire and you'll see the voltage increase.
You're losing about a half volt in 15 feet which seems excessive...is anything getting warm to the touch?
I'm sure the engineers will chime in with ohm's law and wire gauge recommendations...
bw_hunter is offline
Old 05-27-2012, 07:01 AM
Guest
Guest47904's Avatar
Re: Low voltage
You have to follow the path of both positive AND negative. Take your voltmeter when the engine is running and first measure from the output terminal of the alternator to the engine block. Then move the negative meter lead to the frame of the front clip. You will probably notice a drop in voltage.
My suggestion is clean and possibly up the size of ground strap from the engine to the frame. At least clean both ends and be sure its tight.
Now because its a unibody, its relying on the body to carry the connection from the front to rear frame. I would put a clean connected strap from the front frame to the rear frame. Now be sure the battery negative terminal has a good clean connection to the rear frame.
Done.
Guest47904 is offline
Old 05-27-2012, 09:58 AM
Re: Low voltage
Check this "how to".......
Trunk mounted battery
Injuneer is offline
Old 05-29-2012, 12:09 AM
my1994z28's Avatar
Re: Low voltage
Thanks for the link Fred....I used Accel lighting battery cable..I think i might have figured out the problem,my buddy grounded the negative cable to my nitrous bottle bracket inside the wheel well..I am going to get a longer cable and ground it to the frame rail,hope this takes care of the voltage drop..
Old 05-29-2012, 11:11 PM
Re: Low voltage
What gage is the Accel cable?
Injuneer is offline
RUENUF
03-13-2016 03:37 PM
speedracer1280
09-08-2015 06:12 AM
WPHIG2
08-27-2015 06:37 AM
08-07-2015 01:26 PM
C4m4roJoe
07-19-2015 10:59 PM
Quick Reply: Low voltage
