How much does a speedo change from gears?
I actually wasn't sure where to post this.......it's kind of PCM related........it's also rather Drivetrain releated.......
Oh well.
As the title states - how much and in what direction will my speedometer and odometer be altered and in which direction when going from 3.42's to 4.10's?
Oh well.
Re: How much does a speedo change from gears?
the speedo will read high, possibly as much as reading 90 when you are doing 65, so your odo will rack up miles quicker then normal, I went from 2.72s to 3.73s in my old IROC, and it would hit the speed limiter(110mph) at somewhere near 65-70mph
Good to know......thanks.
I was rather hoping it wouldn't be all the much, but seeing as how it may effect it a lot - I'm going to send my PCM away to Ion for a re-zappin.
The error can be calculated from the gear ratios:
4.10 / 3.42 = 1.20
Speedo will read 20% higher than actual speed.... e.g. - read 72mph at a true 60mph, 96mph at a true 80mph, 120mph at a true 100mph.
Other thing to consider is the affect on the odometer. When you drive 1,000 miles, your odo will rack up 1,200 miles.
4.10 / 3.42 = 1.20
Gee........there's a way to keep the K off a car.
If going on a long trip and have a PCM that is calibrated for 4.10's - switch them out for 2.73's for the extra milage and the less K on the odometer.
The added cost of the switch would heavily outweigh the savings though.
Just thinking of the possibilities.
Thanks Injuneer.
Thanks Injuneer.
Originally Posted by Ken S
I believe odometer fraud is a felony, with up to 7 years of prison...
Rich
Lt1son
12-31-2014 01:35 PM
07-04-2005 05:00 PM
