Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 F-Body Technical Discussion > General 1967-2002 F-Body Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 04-21-2008, 08:52 AM   #1
19z28camaro02's Avatar
Send a message via MSN to 19z28camaro02
How long do YOU let RTV set for?
So I put my water pump on yesturday. Let the Black RTV cure for the appropriate amount of time. I have yet to add coolant to my car so as of now it is between bone dry and moist. How long would you let the RTV set for before you add coolant? (in hours please)?
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
__________________
D'Oh
19z28camaro02 is offline   Reply With Quote
Old 04-21-2008, 09:39 AM   #2
Send a message via MSN to Mortify
I waited 36 hours... but its usually between 24-48 I believe.
__________________
1993 Trans Am M6 - Black/Leather
Moroso CAI, Hooker LTs, 4" ORY, Magnaflow Cat-back, PCM4Less..
Mortify is offline   Reply With Quote
Old 04-21-2008, 09:44 AM   #3
For water pump, I don't wait at all.
shoebox is offline   Reply With Quote
Old 04-21-2008, 11:17 AM   #4
Regular RTV is corrosive and should not be used on aluminum parts. There are non-corrosive sealants that can be used, most are gray.
Also with the improvements in quality of modern engines I see no reason to smear RTV all over my gaskets. Usually does more harm then good.
If you feel you have to have something, a light spray adhesive/sealant should be all that's needed.
In any case RTV does not need to be full cured, just "setup", which only takes a few minutes. It used to say this in the directions?
__________________
NQR Racing
Blk 84 Z28 (race car)
Wht 97, M6, SS, Conv., Bld. #35, Free Mods., 160* thermo., 3:73 Gears, MSD Coil & Wires
14.045 1/4m @ 99.52mph, 3816lb., sea level, 87*
Z28SORR is offline   Reply With Quote
Old 04-21-2008, 11:23 AM   #5
RTV is actually corrosive on aluminum?
__________________
D'Oh
Old 04-21-2008, 12:14 PM   #6
Super Moderator
Garage
Hopefully, it was Permatex Ultra Black. Permatex Ultra Black RTV is an oxime silicone (ref. Permatex Technical Data Sheet SIN: 834-300), which will not corrode aluminum. Oxime silicones are O2 sensor safe, as well. Permatex Black is an acetoxy-cure silicone sealant (vinegar smell), and can be corrsive to copper and aluminum.
__________________
Fred
94 Formula A3+1: 381ci all-forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons/CNC LT4 heads/Comp Cams custom solid roller/TH400+GearVendors OD/4.11's/Strange 12-bolt/300-shot N2O/Spohn Suspension/6-pt roll bar with integrated SFC's/full AutoMeter instrumentation/MoTeC M48 Pro engine management system/a few other odds 'n ends.
My website is down. Hopefully, links/photos be restored in 2 or 3 weeks.
Injuneer is offline   Reply With Quote
Old 04-21-2008, 12:20 PM   #7
Send a message via AIM to mdacton
Try the right stuff from permatex.
Sets up in 1 minute...
mdacton is offline   Reply With Quote
Old 04-21-2008, 12:31 PM   #8
Quote:
Yah, not sure there is much of this left out there any more. Just a note of caution. I've seen many thermostat housing ruined by this stuff and a few intakes.
__________________
NQR Racing
Old 04-21-2008, 02:13 PM   #9
Super Moderator
Garage
From Permatex, for the Ultra Black:
Quote:
Permatex Ultra Black Gasket Maker cures on exposure to moisture in the air. The product dries tack free in two hours and fully cures in 24 hours. Cure times will vary with temperature, humidity and gap.
Old 04-21-2008, 04:24 PM   #10
I used the ultra black, let it set up for about 20 hours. Filled it this afternoon, runs like the dream.
__________________
D'Oh
Old 04-25-2008, 12:51 AM   #11
95camaroinok's Avatar
Send a message via Yahoo to 95camaroinok
+1 on right stuff. Have used it in MANY applications and it is true in advertising that vehicle can return to service Immediately. I even sealed my leaking windshield with this stuff Have used it on valve covers and other components that only use an "RTV" type gasket with excellent results.
__________________
01 Durango Sport
95 Camaro 3.4 A4 sold
95 Camaro Z28 LT1 A4 sold
95camaroinok is offline   Reply With Quote
Old 04-27-2008, 11:16 AM   #12
Back to the originall question...
ON the water pump I only wait for the amount of time it takes to put everything I took off back on. If you have waited over night you are just fine.
gnomee is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
