How long do fuel filters last? - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 07-16-2006, 04:45 PM   #1
Just wondering how long they last usually? mileage wise
I kno the techs at my work include a fuel filter replacement on 30K mile service on a "new" car.
I got 30k on mine now, my dad believes they last 100k miles...
Any brand recomendations?
I think i replaced mine last with a Fram fuel filter
Bow94z is offline   Reply With Quote
Old 07-16-2006, 04:48 PM   #2
01Z
01Z's Avatar
Re: How long do fuel filters last?
Hi. I use wix from napa. One dirty load of gas in your tank and it is time to change your filter and it can happen again at any time. Assuming that doesn't happen then 30k would be alright but I like to change it out once a year. A dirty filter can cost you a fuel pump btw....
01Z is offline   Reply With Quote
Old 07-16-2006, 04:58 PM   #3
My stock car had the same one on it till 180k miles. I replaced it last year. They should last a long time.
MyShibbyZ28 is offline   Reply With Quote
Old 07-16-2006, 05:07 PM   #4
Quote:
I agree with you, cause you figure within 30k miles, how many times does your tank get fillled.
So think of all the chances of getting bad "dirty" gas
Old 07-16-2006, 05:25 PM   #5
Not true about the pump for f-bodies. Pump in tank. Filter upstream.
Kwiksilverz28 is offline   Reply With Quote
Old 07-16-2006, 05:50 PM   #6
Super Moderator
No... there is a sock on the pump suction, the main filter is "downstream" (after) the pump. I doubt a clogged filter would "cost you a fuel pump". The engine would stop running when it got that bad.
Injuneer is offline   Reply With Quote
Old 07-16-2006, 06:03 PM   #7
myslowcamaro's Avatar
before i went out on comp, shell actually had to clean all of their storage tanks for the new alcohol added fuels to prevent separation. it used to be before, the motor would sit 5-6" off the bottom of the tank, and the shutoff level for dirt, water, etc was 3" but too often sludge was still getting mixed up with the outbound gasoline. now, its .8" for a warning, and 1.5" inches of anything other than gas will automatically shut the line down until the tank is cleaned again. so shell brand was one of the worst, now one of the cleanest.
myslowcamaro is offline   Reply With Quote
Old 07-16-2006, 06:07 PM   #8
hmm thats some good info scott
Old 07-16-2006, 06:28 PM   #9
They will last nearly forever...but they get dirty sooner than that. It never hurts to change the filter. Clean gas is a good thing.
shoebox is offline   Reply With Quote
Old 07-16-2006, 08:12 PM   #10
I change mine once a year period. Ive seen 15 year old cars with 30k on them have stopped shut filters. dont want to burn up any pumps.
my94blackz is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Trans issue PCLZ28 Drivetrain 7 12-24-2015 06:19 PM
Fuel Pump, Injectors, Opti, or all of the Above? Alex Barnes LT1 Based Engine Tech 16 01-24-2015 11:21 PM
Need Help swapped gas tank 1998 to 2000 no preasure Deadbolt24 LS1 Based Engine Tech 1 01-19-2015 02:29 PM
Fuel filter change 30thZ4C Fuel and Ignition 0 12-26-2014 06:09 PM
HELP!! Car is cursed. runs rough after 2 min of driving, msd problem? supercharged94Z28 LT1 Based Engine Tech 12 02-24-2003 11:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
