How hard is it to spin the tires with ls1?
I recently purchased a 2001 z28 m6 with 20k miles. It has great power but does not seem to break the wheels loose except on the 1st to 2nd shift when I am running it hard. I am a little new to driving a manual so it suprised me that I am not squaling the tires more. Is this normal?
lift clutch....PUSH gas to floorboard
done!
actually, since i replaced the old tires with decent ones, it is alot harder to really spin them. unless i drop the clutch in 1st, or really power shift it into 2nd....i don't spin!
i remember the crappy tires i had on my lt1 would occasionally chirp 4th gear on a hard shift. i installed the firestone firehawk SZ50s and i never even chirped 3rd after that...they stick like glue (for a street tire)
done!
My '98 has a traction control button or something. If I try to spin the tires, it puts tension on the gas so I can't hammer it. I can actually feel my foot being pushed off the throttle. I don't normally spin my tires too much. I baby that car...lol.
I dont have traction control in my car. The car jumps up and goes but does not break the tires loose. I have even reved it to 2k rpms and slowly let the clutch out as in a normal start. The car just jumps and takes off.
Your tires will have a lot of influence on how easy it is.
It's a lot easier to keep them spinning than to get them to break traction.
LS1, LT1, etc. should have no problem breaking traction, you've just gotta let the clutch grab a little faster than you normally would.
But I normally try not to spin the tires- getting them to not spin while not having the engine bog is a lot harder for me- and a lot more fun when I fly away from the light.
okay, I've got an auto with the 3.23 gear, and I can just stand on the gas from a stop and lay rubber till no tomorrow, I can just take off a little quick and get them to spin with no problem. I've floored it going 15-20 and when it shifted into 1st it spun the tires through 1st and half way into 2nd at 60mph.
And it will always spin the tires a little when it shifts from 1st to 2nd at WOT.
AronZ28, I agree. In 2002 I test drove a brand new Trans Am auto. I stomped on it and got it side ways through an intersection! One of my top 5 test drives ever. My z28 feels faster in every way but I thought it would spin the tires easier then the auto did. I am not going to drop the clutch, I am sure that will work but I dont want to damage anything. I was sure that slipping the clutch at 2k rpms would do it. Again, I am new to a manual and taught myself. It may be something I am doing wrong?
very easy with a stock LS1.
However, I can only spin my tires by holding the brake and mashing the gas, and the only other way would be from a stop around a sharp turn.
Since I have 2.73 gears, LCAs, and Adjustable Torque Arm, its really hard to break them loose. They will squeal a LITTLE bit from a stop since i did my headers, but it hooks up nicely
go like ~15-20 mph, leave it in first gear and then just hit the gas pedal as fast as u can. that should do it for you too, and mine was a less powerful stock LT1. Otherwise, as you know you can spin them deffinatly just by revin it and droppin the clutch
If my tires are cold - I can spin them with a little bit of a clutch drop and lots of gas.
If I've been driving on the highway for a while - it takes a brutal 4 to 5K sidestep of the clutch to break them loose - even then they only haze for a second and then hook.
Extremly soft rubber and lots of contact patch though - Yokohama AO32R's..........
Comp Drag Radials =
Comp Drag Radials =
