How do you remove the A-Pillar trim piece?
Does your car have T-top's or is it a hardtop? If it's T-tops remove the two screws where the T-top locks in(obvious I know but I had to say so) Then just slowly pry it off the pillar. There are two seperate tabs that keep it locked into place. They are evenly placed about 10 inches apart. Those will probably be the hard part of getting it off. On the side of the pillar where the door is at the trim kinda wraps around the metal part so try to pry from that side instead of the windshield side. It'll come off with some convincing. If you have a hardtop do the exact same thing, just be careful of the trim that goes up over your head all the way back to where the seatbelt is bolted to the roof. Make sure that is all completely free of obstruction otherwise you WILL break that part, especially the little tabs at the end. Good luck.
I just did this last night. The part of the A-pillar that sits above the window glass needs to be pulled from the outside. It has 3 clips that clip onto the metal structure underneath. The part that runs down by the windshield has 3 or 4 clips that clip into the metal underneath as well, but they face the opposite direction. Pull this part towards the interior of the car. It takes a good pull to undo them, but with some care it should pop right off.
*Edit: The part above the window needs to be pulled towards the outside.
10-31-2016 11:09 AM
04-16-2015 09:57 AM
12-04-2014 11:56 AM
