Hissing noise when turning a/c off
My a/c makes a hissing noise when I turn it off for a few seconds then quits? Would this be a vaccine leak or normal operation
Posted from Camaroz28.com App for Android
Re: Hissing noise when turning a/c off
Are you talking about inside the car when you move the mode control? It is vacuum operated, so yeah it will hiss for a few seconds as it bleeds off the vacuum. It has nothing to do with a vaccine.
Meant to say vacuum. Stupid auto correct. But anyways I was wondering because where all 3 vacuum lines meet at the check valve under the hood in my car had no check halfheartedness it was just a 3 way port for them all 3 to connect to. It was shaped like a fork in a road so I replace it with the correct check valve from GM. Wanted to make sure I didn't screw anything up
squarehead
11-21-2014 08:02 PM
formula79
26
08-05-2002 12:21 PM
