help with a narrowband gauge
I have a Autometer Cobalt Narrowband o2 gauge and im not sure why it just bounces all over and when i pin the pedal to the floor it just slams into the rich side...so im just wondering what wire off of which o2 sensor should i have hooked it to...any help is appreciated
When you put the throttle on the floor, the PCM enters "power enrichment" mode. It sets a much richer target A/F ratio, because that's what is require to make more torque and HP. 14.7:1 is good for emissions and fuel mileage, but not very good for power. Typical target A/F ratio in PE mode, with stock tuning is about 11.7:1.... e.g. - "too rich" factory programming. At that A/F ratio, the stock narrow-band sensors are so inaccurate as to be pretty much useless. Again, all you can determine from your narrow-band driven A/F gauge is that the PCM is in PE mode.
The gauge is not really very useful.
RX Speed Works
09-11-2015 03:31 PM
jackpawt883
09-10-2015 08:53 PM
[Interior] Interior protection
themex2002
09-02-2015 03:47 PM
