Help me! - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 03-10-2014, 03:39 AM   #1
Help me!
Normally im a smart girl. Obviously not today. I jumped my car (96 ss) directly from the battery. It's messed with my anti theft and locked me out of the stereo system. I cannot set my clock, the radio will turn on via the dial but no sound comes out. I cannot switch between am/fm/cd, it will not even attempt to accept a cd or anything. I know there is some type of key sequence for this but I cannot find it. There is nothing in my owners manual, resetting the battery didnt help and neither did removing the radio fuse. Basically, my car thinks i stole it. Awesome. I cannot find the correct phrase to google that brings up anything useful either. Any help would be appreciated! Thanks!
00redsvt is offline   Reply With Quote
Old 03-10-2014, 04:20 AM   #2
Re: Help me!
Oh, and it doesn't say LOC or anything, it just shows three dashes where the time should be and won't let me do anything?
Old 03-10-2014, 10:24 AM   #3
Super Moderator
Re: Help me!
According the the 1996 Owner's Manual (pages 3-17 to 3-19) if you see three dashes (---) the security system is not set, and you have to start from step 4 of the security programming procedure. If you do not have a manual, you can read and download one here:
Courtesy of Shoebox
http://shbox.com/pdf/1996camaro.pdf
Injuneer is offline   Reply With Quote
Old 03-12-2014, 03:00 AM   #4
Re: Help me!
Thanks. I followed all those instructions and still nothing. I don't know what happened to it. I ended up leaving the battery unhooked for half an hour and it was fine after that. No clue what was going on with it. Thanks for trying to help though, appreciate it.
Old 03-12-2014, 08:46 AM   #5
Super Moderator
Re: Help me!
So the problem is solved?
Old 03-14-2014, 09:38 PM   #6
Member
GaryDoug's Avatar
Re: Help me!
Everything in the car, PCM, BCM, radio, has a microprocessor like a PC and you know how easy it is to glitch one of those ;-). I suspect that's what happened when the battery surged while jumping. You had to "reboot".
GaryDoug is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
