Help: Indentify/Find/Removal
Help: Indentify/Find/Removal... BATTERY DRAIN Part 4!
First the identify part:
red wire with the exposed tip on the right, is that ok?
http://www.imagemagician.org/images/...f/DSC00054.JPG
This grey big connector in the center of the pic gets power still, would that cause a drain?
http://www.imagemagician.org/images/...f/DSC00056.JPG
Now in this pic what is the thing on the right, it looks liek if I took the cap off it would fit in the middle thingy, sorry for overuse of "thing"
http://www.imagemagician.org/images/...f/DSC00055.JPG
Ok, the find part:
I wan tto find wiring diagrams, schematics, blueprints, egyptian hyrogliphics, anything! on my car.
And now the removal, I want to remove the stupid blower fan for the ac and heat, i dont have either, so i unplugged it do i just remove the bolts around it or is there another part or connection i'll need to fiddle with?
You can kinda see it in the pic at the top:
http://www.imagemagician.org/images/...f/DSC00045.JPG
Thank you!
Ok, the find part:
Thank you!
Re: Help: Indentify/Find/Removal
Chilton's has a 3rd Gen F-Body manual with some decent wiring diagrams. They have the 89 2.8L, 5.0L TBI, 5.0L TPI and 5.7L TPI engine/computer diagrams and 2 pages of body wiring.
If you identify your engine, I could fax you the engine and body diagrams.
thanks
Woohoo picture time again, hey what bout my other questions up there
ok here is where i get a reading:
http://www.imagemagician.org/images/...f/DSC00059.JPG
http://www.imagemagician.org/images/...f/DSC00061.JPG
thats the hose to the resivoir(sp) from the radiator, both bolts draw between 0.10 and 0.13 when i check for DC voltage.
well I removed the battery and teh volt thing still reads that hose bolt the same so i guess thats somethign else, now that stupid fan thing in engine compartment on the passenger side i got 2 bolts out and it swings around, but somethign in the bottom is holding it in, hwo do i get to that?
Re: Help: Indentify/Find/Removal... BATTERY DRAIN Part 4!
Ok, the find part:
Thank you!
Ok, the find part:
Thank you!
what is a fan relay? Mechanic had to run a new line for the radiator fan, i guess that explains the new part.
Thank you!
Thank you!
04-02-2014 12:45 PM
