Help! General Maintenance Question!
Old 08-13-2013, 01:38 PM
dtortora's Avatar
I purchased a 1997 Chevrolet Camaro Coupe Base Model (3.8 Liter SFI V6 4-Speed Automatic 16" Aluminum Wheels). I purchased it with 121,000 miles in May 2012. Currently, it has 131,000 (August, 2013). Since I have purchased the car last year, I have:
* Replaced the Front (2) and Rear (2) O2 Sensors (Total: 4)
* Replaced Fuel Filter
* Replaced 2 Ignition Coils
* Replaced Fuel Regulator
* ALL-NEW Fluids (Brake Fluid, Transmission Fluid, Power Steering Fluid, Radiator Fluid)
* 3 TOTAL Oil Changes
* 1 Tire Rotation
Is there anything else I should look at getting replaced? I need this car to last as long as possible!!!! Are there any fluids/filters I missed that need changing? Are there any parts I should look into replacing at this mileage? I cannot afford a new car and need this car for the next few years!
dtortora is offline
Old 08-13-2013, 05:05 PM
parkers Z28's Avatar
Re: Help! General Maintenance Question!
How does the belt look ??? eventually that last coil pack will need to replace ...if you haven't looked at the sticky on V6 mystery missfire you should check it out
parkers Z28 is offline
Old 08-15-2013, 07:13 PM
Tibu21's Avatar
Need help finding transmission cooling line. Called dealer said it was discontinued where can I get one?2001 z28
Tibu21 is offline
Old 08-16-2013, 11:40 AM
You need to start your own thread. Not a good idea to tack your question onto someone else's topic.
Injuneer is offline
Feffman
10-09-2015 05:42 AM
ChrisFrez
03-01-2015 01:33 PM
NewsBot
02-26-2015 02:10 PM
95z_28_camaro_4_Ivan
12-19-2014 08:48 PM
Quick Reply: Help! General Maintenance Question!
