Help! General Maintenance Question! - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 08-13-2013, 02:38 PM   #1
I purchased a 1997 Chevrolet Camaro Coupe Base Model (3.8 Liter SFI V6 4-Speed Automatic 16" Aluminum Wheels). I purchased it with 121,000 miles in May 2012. Currently, it has 131,000 (August, 2013). Since I have purchased the car last year, I have:
* Replaced the Front (2) and Rear (2) O2 Sensors (Total: 4)
* Replaced Fuel Filter
* Replaced 2 Ignition Coils
* Replaced Fuel Regulator
* ALL-NEW Fluids (Brake Fluid, Transmission Fluid, Power Steering Fluid, Radiator Fluid)
* 3 TOTAL Oil Changes
* 1 Tire Rotation
Is there anything else I should look at getting replaced? I need this car to last as long as possible!!!! Are there any fluids/filters I missed that need changing? Are there any parts I should look into replacing at this mileage? I cannot afford a new car and need this car for the next few years!
dtortora is offline   Reply With Quote
Old 08-13-2013, 06:05 PM   #2
parkers Z28's Avatar
Re: Help! General Maintenance Question!
How does the belt look ??? eventually that last coil pack will need to replace ...if you haven't looked at the sticky on V6 mystery missfire you should check it out
parkers Z28 is offline   Reply With Quote
Old 08-15-2013, 08:13 PM   #3
Need help finding transmission cooling line. Called dealer said it was discontinued where can I get one?2001 z28
Tibu21 is offline   Reply With Quote
Old 08-16-2013, 12:40 PM   #4
Super Moderator
Quote:
You need to start your own thread. Not a good idea to tack your question onto someone else's topic.
Injuneer is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
MVP Track Time 2015 Track Dates Feffman Autocross and Road Racing Technique 4 10-09-2015 06:42 AM
Camaro Podcast #495 - First Camaro Ever Built Lives ChrisFrez CamaroZ28.Com Podcast 0 03-01-2015 02:33 PM
NEWS: Very first Chevy Camaro found and restored NewsBot 2010 - 2015 Camaro News, Sightings, Pictures, and Multimedia 0 02-26-2015 03:10 PM
Question on Crankshaft...? 95z_28_camaro_4_Ivan General 1967-2002 F-Body Tech 2 12-19-2014 09:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
