Help! Electrical Problem...
Old 07-18-2005, 01:45 PM
twiztedone01's Avatar
Ok my car was stored for 8 months while i was away andwhen i came home i took the cover off and started it up no problem after replacing the battery... Well i noticed immediately as soon as i started it that the beeping sound you get when you put the key in the ignition or just start the car... would not stop at all, even after the car was running. So after an hour of it driving me nuts i yanked the fuse, unfortunately it also controlled my interior lights and a couple other things. Yesterday i installed a new cd player and unfortunately, i need to have that fuse in to make it work... after putting the fuse in and turning the car to acc the beeping sound keeps going and the radio turns on for about a minute before turning off... My question is what the hell could be causing that constant beeping and how do i fix it...
EDIT: I also noticed that with the stock radio in, everytime i turned the car on the clock would reset to 12:00 if that helps at all...
twiztedone01 is offline
football4life
10-04-2015 07:48 AM
plattted
Parts Wanted
09-13-2015 07:17 AM
Daluchman1974
09-11-2015 06:12 AM
plattted
West South Central
09-07-2015 02:45 PM
tdigger9899
09-07-2015 10:56 AM
Quick Reply: Help! Electrical Problem...
