Help!!
Old 02-21-2016, 06:11 PM
Cherry93's Avatar
Help!!
I have a 95 z28 that will randomly shut itself off. Sometimes it will run for weeks just fine and sometimes it will shut off 3 times in five minutes. When it dies it's just like someone shut the key off. Most of the time it will start right back up but there has been a few times going down the road that it would just crank until I came to a stop and then it would fire back up. There has also been a few times that it would die going do the road and I would throw it into neutral and the motor would fire back up. Starter wouldn't crank, the motor would just fire back up on its own. I've read a lot of threads of similar problems and everyone always suggest coil getting heat soaked so I'll save people the time and tell you that is not the issue, it is not temperature related. I have also put a new opti in it about 6 months ago. Only things I could possible think of would be ignition switch, opti, bad pcm, or bad ground.. I guess I'm just looking to see if anyone else has had an issue like this or has any other insight on what the issue could be. Thanks
Cherry93 is offline
Old 02-21-2016, 06:34 PM
gaedbo's Avatar
Re: Help!!
Go to the Computer and Diagnostics Forum at this website. Click on Scan9495. It is a free scanning software that Gary Doug has provided to troubleshoot issues related to 94 and 95 Z28's. Read thur those threads to see what you will need to do to make it work for your 95.
gaedbo is offline
Old 02-21-2016, 06:53 PM
Cherry93's Avatar
Re: Help!!
I will check that out thanks! I should of mentioned that I did have access to a scan tool that would work with my 95 and even ran live feed for a week and everything was working perfectly. When the car would die everything would behave the same way as if I were to shut the key off. Power was just gone to everything except for headlights, radio, etc. and after about 10 seconds it would ding like when you turn the key to on and the dash would come back to life again.
Cherry93 is offline
Old 02-21-2016, 10:43 PM
Re: Help!!
Check the ignition switch. They are getting old. Seems like over the past couple years there have been increased problems, including melted terminals. Losing power intermittent to/from the switch would explain shutting off, and the appearance that the switch had just been turned to "run" when it restarts.
Injuneer is offline
Old 02-24-2016, 01:37 PM
Cherry93's Avatar
Re: Help!!
Thanks for the response Injuneer! I'm going to try and dig into it this weekend. I will post back with what I find.
Cherry93 is offline
Old 02-24-2016, 04:09 PM
Re: Help!!
Some info in the first paragraph of this that might be helpful:
Courtesy of Shoebox
4th Gen F-body Ignition Switch Replacement
Injuneer is offline
Old 02-27-2016, 05:16 PM
Cherry93's Avatar
Re: Help!!
Pulled the ignition switch out today and found the connector was burnt so I swapped the pigtail out from an old harness I had laying around and put in a new switch and so far so good! Now, I starting messing with my drivers window as I've had a problem where it will not roll down but always rolls up just fine. I pulled the plug off the motor and it has power to the motor when I push the switch to roll it up and to roll it down so I went and got a new motor. I plugged the motor in to test it before I put it in and same story. Will roll up but still won't roll down. I'm stumped.
Cherry93 is offline
Old 02-27-2016, 06:46 PM
Re: Help!!
Could be the switch. When you press "down" does the motor make any noise, like it's trying to move the window?
Injuneer is offline
Old 02-27-2016, 07:31 PM
Cherry93's Avatar
Re: Help!!
I can hear a very very faint noise every now and then but not everytime. According to my voltmeter it's getting full power to the motor when I push the switch though. I think I'm going to get a switch anyway and try it out.
Cherry93 is offline
Old 02-27-2016, 10:05 PM
94Z28LS1toLT1's Avatar
Re: Help!!
I remembered like 5 yrs ago I had the same exact problem what u described about the window,but motor,switch,etc were fine took to a place and found out my rivets were preventing my window from going down,like I had to move the window while pressing the switch to down n the window would go down, n when i pressed the up on the switch up worked perfectly
94Z28LS1toLT1 is offline
markzzzz
08-17-2015 11:08 AM
MrHyde
05-11-2015 10:26 PM
Matt W
04-24-2015 12:54 AM
AlaskaZ28
04-17-2015 08:54 AM
FredM
04-10-2015 02:56 PM
Quick Reply: Help!!
