heater weak
Re: heater weak
Unfortunately, you posted in the 2016 Camaro News forum. Let's move this to the 4th gen forums.
Typical problem is a clogged heater core. Do the lines to and from the heater core both get hot?
If the core is plugged, pull the heater lines off the water pump, and flush the core in both directions with a moderate pressure garden hose. Cover the Optispark distributor so there's no chance of it getting wet.
