Headlight motor.
Old 06-16-2005, 12:19 PM
SpoolinV8ETR's Avatar
Headlight motor.
I have a 94 Formula. When you turn the lights off the driver side keeps going and going till it finally stops. Both lights go up and down just fine. The motor just keeps running.
Is there anyway to make it to the head lights to popup unless the headlights are on? looks weird with the lights up and only the parking lights on ya know?
SpoolinV8ETR is offline
Old 06-16-2005, 07:12 PM
Kataklysm's Avatar
Re: Headlight motor.
Your headlights should be down all the time unless the lights are on...Your descibing the symptoms of a stripped headlight motor gear...just buy a brass gear off ebay or someone here and put it in.
Kataklysm is offline
Old 06-16-2005, 10:30 PM
There down all the time till i turn on either the parking lights or the headlights. You wouldnt think they would popup if only the parking lights are on though.
Or are you talking about the continous runnin?
Old 06-17-2005, 03:52 PM
moparman's Avatar
It's probably the gear in the motor. Search for "headlight fix".
moparman is offline
Old 06-18-2005, 12:15 AM
BacardiTA's Avatar
Motor runs and makes grinding noise, headlights pop-up when only the parking lights are turned on, headlights pop-up when arming the alarm... all symptoms of a stripped gear. I have one too and feel your pain. Good news is there's a cheaper alternative then buying a $200+ motor. These links will tell ya more then ya ever want to know about it and where to buy:
http://www.rodneydickman.com/n113.html
http://www.bfranker.badz28.com/headlightfix/
http://www.bfranker.badz28.com/headl...earinstall.htm
BacardiTA is offline
Old 06-18-2005, 09:59 AM
Thanks everybody!
93 RedBird
11-15-2015 08:24 AM
Mikes 1994 z28
10-10-2015 07:55 AM
Greg88
09-20-2015 07:14 PM
Daluchman1974
09-11-2015 06:12 AM
jackpawt883
09-10-2015 08:53 PM
Quick Reply: Headlight motor.
