header crack
header crack
i took my car to get checked out, and I have a crack in the header. will it hurt running the car with a crack in the header for about a month? i wanna install performance headers but i need to wait a month for the $$$.
also, my car has a tick under acceleration, it sounds like its from the exhaust leak, and i searched on the forums and people said that could be causing it?
thx
thx
Re: header crack
Without knowing as much as the year of your car, or the engine, its very hard to answer your question in detail. But, in general, a severe leak, close to the head can result in a burned exhaust valve. Even a moderate leak will affect the closed loop A/F ratio control on an electronic fuel injection system, causing that side of the engine to run excessively rich. Not something you want to do, but if its a small leak, remote from the head, you probably won't do too much damage in a month.
An exhaust leak will produce a very distinct "tick", particularly when you open the throttle under load.
Re: header crack
it sounds like a baseball card in the spokes of your bicycle tire, kind of.
Re: header crack
Does your car act sluggish when you start from a stop? I had this happen due to a loose sparkplug boot. It would studder slightly OTL, tick every so often under sudden heavy acceleration, car would feel fine in the high rpm. I looked at my engine in the dark to see any arcing or loose plugs, boots etc. Hope it helps.
Re: header crack
yeah, it does studder from a stop... it's like it's getting enough power then kinda dies down a little then goes back to normal... it does only tick when it has that power loss, should i get a tune up and have them replace the spark plugs, would that fix it? or is there an easier way?
thank you
thank you
squarehead
11-21-2014 08:02 PM
