Head lights won't pop up
Old 02-22-2010, 09:13 PM
gritter94's Avatar
So my headlights won't come up I turn the switch the fogs come on, but the headlghts motor doesn't even make a noise? Any ideas on things i should check? Would love it get it fixed before summer!
gritter94 is offline
Old 02-22-2010, 09:24 PM
gritter94's Avatar
Also both lights stopped working at the same time so i don't think both motors pooped out at oncE right ?
Old 02-23-2010, 12:14 AM
Might want to add info regarding the year and model of the vehicle. In any case, it has nothing to do with "Computer Diagnostics...." so I'll move it to "General 67-02 F-Body Tech".
Injuneer is offline
Old 02-23-2010, 12:23 AM
gritter94's Avatar
1994 Pontiac trans am
Old 02-23-2010, 05:25 AM
Could be the headlight door module, located in the drivers front fender on the side of the air filter box (stock location), or the power to the module.
Injuneer is offline
Old 02-23-2010, 08:17 AM
gritter94's Avatar
do those just go bad over time? How do i go about checking it? are they exspensive?
Old 02-23-2010, 02:35 PM
Fuse can blow at any time. Module can fail electrically. My 94 Formula has never had a problem though.
The headlight doors are controlled by fuses #3 and #4 in the underhood convenience box. Check those first. I don't know where to find a schematic for the headlight motors.
The headlights can also fail due to the gears in the motors. Here's a good reference on problems related to the gears:
http://www.bfranker.badz28.com/headlightfix/index.htm
Injuneer is offline
10-31-2016 11:09 AM
Jlo
02-03-2015 09:41 PM
bfmv13trivium
01-14-2015 09:57 AM
nophix
11-30-2014 10:26 PM
AW/whiteZ-28
07-25-2002 04:09 PM
Quick Reply: Head lights won't pop up
