Fog LIGht Replacement 2002 Z-28
Old 10-23-2016, 11:28 AM
JorgeI's Avatar
Can anyone shed some insight, please? I know about the access panel, but how do the bulbs come out? Appreciate the help!
JorgeI is offline
Old 10-23-2016, 05:28 PM
peterpar's Avatar
Re: Fog LIGht Replacement 2002 Z-28
here's a copy and paste from the 2000 service manual.
Fog Lamp Bulb Replacement - Front
Removal Procedure
1. Raise and suitably support the vehicle. Refer to
Lifting and Jacking the Vehicle in General
Information.
2. On Camaro and Firebird vehicles, open the
access door in the front bumper air deflector.
3. On Trans Am vehicles, remove the push pin
retainers which are located at the bottom
center of the front fascia.
4. Disconnect the electrical connector from the
fog lamp.
5. Remove the fog lamp bulb from the electrical
connector.
Installation Procedure
1. Install the fog lamp bulb to the electrical
connector.
2. Connect the electrical connector to the fog lamp.
3. On Trans Am vehicles, install the push pin
retainers to the bottom center of the front fascia.
4. On Camaro and Firebird vehicles, close the
5. Lower the vehicle
peterpar is offline
Old 10-23-2016, 06:53 PM
JorgeI's Avatar
Thanks very much, but the round bulb appears to be encased in a plastic housing. Are the bulb and housing integral? I'm just not seeing any way to physically unscrew the bulb. Maybe a photo?
JorgeI is offline
Old 10-23-2016, 07:11 PM
peterpar's Avatar
I've never had one apart, but pictures I found on Ebay of the replacement lamps show that the socket twist and pulls out from the housing.
peterpar is offline
Old 10-23-2016, 07:19 PM
JorgeI's Avatar
Yeah, thanks it appears it is integrated. I think I can figure it out from here.
JorgeI is offline
