fan shrouds with WP118HD
Old 08-27-2012, 01:58 PM
aknight_sa's Avatar
guys,
i dont want to do any cutting or modifications to the fan shrouds as mentioned in many threads in order to install the meziere WP118HD electric water pump.
i would like to know where should the modification be done and if anyone has a picture to help me out.
thanks
one more question.. should i install the pump then the fans back on.. or leave the electric pump last then tight it on?
aknight_sa is offline
Old 08-27-2012, 03:45 PM
slingshot's Avatar
Re: fan shrouds with WP118HD
You have to cut the upper left corner of the fan shroud on the passenger side fan. I had to do it even with the wp118 (non-hd) pump.
I just replaced the pump after getting over 30k miles out of it this past weekend. I removed the plastic piece on the core support holding the fans, etc up, and then removed the four bolts that go into the passenger side fan. The fan can then be removed from the bottom of the car to get access for the water pump. Then remove and replace the water pump, put the fan back in, and fill radiator with antifreeze (it needs to be drained to do the mod).
slingshot is offline
Old 08-28-2012, 05:38 AM
aknight_sa's Avatar
Thanks for the info, will be working on it tonight!
Formula Steve
09-19-2023 08:31 AM
93 RedBird
11-15-2015 08:24 AM
Matt Dreessen
09-09-2015 09:58 PM
Pwilson59
09-03-2015 08:47 PM
4586
08-24-2015 11:04 PM
Quick Reply: fan shrouds with WP118HD
