Engine Frame mounts for 70 Camaro
Old 04-05-2014, 07:41 PM
cferrel4's Avatar
I have been trying to do a considerable amount of research on the engine frame mounts for my 70 camaro. The car came with no frame mounts. I am going to be putting in a LT1 from a 95 Z28 that I am building with a hot cam and ported cylinder heads for a cruiser.
I picked up a set of SBC engine mounts from my fathers friend. Turned out they are for a 67 to 69 camaro or 70's nova due to the lip on the side. None of the holes would line up though.
So I bought a set of BBC mounts for a 70 camaro from another friend for about $40 to see if i was on the right track. The driver's side motor mount lines up beautifully with the holes already there. The passenger side top 2 holes line up, but the bottom is off by a 1/4 inch easily. just the edge of the hole in the frame meets the bottom bracket hole.
I have searched and searched for a basic SBC mount like for a 327, 307 or even 350 for the 70 camaro, but all I can find is the BB frame mounts reproduced.
I am under the impression if i use the correct mount and an earlier SBC engine mount this will bolt right in with no problem, then just use a different transmission cross member.
I have everything from the 95 Z28 as its a complete donor. Should I try and reuse the motor mounts that where part of that K-Frame? Anyone have another suggestion for a motor mount that I can use/try? Hoping to keep the existing holes.
cferrel4 is offline
Jazsun
12-29-2014 12:14 PM
CaRParts102
12-06-2014 08:45 AM
07-04-2005 05:00 PM
DubbyZ28Camaro
08-04-2002 12:53 PM
Omega9
08-02-2002 12:33 AM
Quick Reply: Engine Frame mounts for 70 Camaro
