Electronic Heater Core????
Old 11-20-2014, 09:15 PM
Black93lt1's Avatar
So i have been driving my newer car in the mornings because its just too cold for the z28. When i got to thinking if any1 has done this or how difficult or possible it would be to put an electronic heater core so she heats up faster.
Black93lt1 is offline
Old 11-21-2014, 07:42 AM
Re: Electronic Heater Core????
You could use the optional 120V plug-in oil heater to keep the engine warm overnight.
If you simply don't get enough heat out of the stock heater core, it probably needs to be flushed out. And, if it's that cold where you live, make sure you are running the correct LT1-specific thermostat, stock 180*F, and that it is working.
Injuneer is offline
Old 11-21-2014, 08:01 AM
Black93lt1's Avatar
Yeah I have a brand new stock thermostat and it takes like 15 mins to warm up I guess I'll have to check out getting it flushed then
Old 11-21-2014, 08:21 AM
You can flush the heater core with a garden hose.
Injuneer is offline
Old 11-21-2014, 11:18 AM
Black93lt1's Avatar
Could you explain?
Old 11-21-2014, 01:52 PM
You take the supply and return lines off the water pump, and put a garden hose on one end, and flow water through the core. Reverse, flowing water from the opposite heater hose. Flush until crud stops flowing out.
Do not get water on the Optispark distributor. Do not apply full house water pressure to the heater core. Make sure you refill the cooling system correctly, getting all the air out.
4th Gen LT1 F-body Tech Articles
Injuneer is offline
Old 11-21-2014, 05:08 PM
Black93lt1's Avatar
Ok sweet thanks
Old 11-21-2014, 07:30 PM
nikko's Avatar
Lightbulb Re: Electronic Heater Core????
Good info injuneer I never thought of the core to flush .Now I know an easy way.Next spring unless we get a surprise early thaw here in Mich
nikko is offline
drt
09-27-2015 04:39 PM
Fatdog2
09-16-2015 11:04 PM
Pwilson59
09-03-2015 08:47 PM
Henson071
08-04-2015 09:32 AM
ducttape1975
07-10-2015 06:29 PM
Quick Reply: Electronic Heater Core????
