Door/Window one-piece Weatherstrip Replacement difficult?
I have a 1994 Camaro and the driver side window seal has shrunk over the last 11 years and I've done all kinds of window adjustments and the rubber just won't seal in the upper rear corner of the window. The rubber has just shrunk and the glass cannot be adjusted any closer/tighter.
I saw I can buy the piece from GMPartsDirect for around 78$. What I am wondering is how difficult is this to replace. I see there is some kind of groove the upper portions around the window run in. Is this very difficult to replace, and does any one have any instructions on how to go about doing it. Has anyone done it?
Any advice or instruction would be greatly appreciated. Thank you...
Brian Kremling
Hallettsville, TX
Brian Kremling
Hallettsville, TX
Re: Door/Window one-piece Weatherstrip Replacement difficult?
I just replaced the weatherstripping on my t-top car all the way around, not hard at all. just have to push it up into the grooves it fits in, go for it
