Gas Tank Building Up Pressure
Old 10-16-2006, 04:27 PM
JC95Z's Avatar
Ok so my basically stock 95 z runs great when you first start it and she's cold. After she warms up and you have been driving her she will backfire and and chug at first blip of throttle. If i get out and unscrew the gas cap it lets alot of air out and she will run better. Got a new gas cap and still does it. Any Help Please!!!!!!!!
JC95Z is offline
Old 10-16-2006, 04:29 PM
StephenDeli22's Avatar
Re: Gas Tank Building Up Pressure
It is normal for the gas tank to have that hissing sound of pressure when you take the cap off. I dont think that and your backfire problem is related.
StephenDeli22 is offline
Old 10-16-2006, 04:42 PM
JC95Z's Avatar
yeah i know there is always the hissing sound when you first take off the cap but this is alot of pressure it will actually let pressure out for about a minute and if i let it all out the car will almost run fine. doesnt make any sense. I actually drilled a hole in the new cap and it wont build up the pressure anymore but it does still hessitate when warm WTF.
JC95Z is offline
Old 10-16-2006, 04:44 PM
WS Sick's Avatar
Check the tank vent to the carbon canister, there is a solonoid that sends the extra pressure to there.
WS Sick is offline
Old 10-16-2006, 05:18 PM
JC95Z's Avatar
This is kinda what i was thinking. This is located in the rear quarter correct?
JC95Z is offline
Old 10-16-2006, 05:40 PM
There's no solenoid.... there's a spring actuated valve. Sounds like the pressure relief valve may not be working.
http://shbox.com/1/evap_system.jpg
Injuneer is offline
Old 10-16-2006, 05:51 PM
JC95Z's Avatar
AWESOME. Thanks this will help alot.
JC95Z is offline
Old 10-17-2006, 08:42 AM
WS Sick's Avatar
Does the solonoid on the side of the intake manifold allow the fumes into the manifold or am I on the wrong track?
WS Sick is offline
Old 10-17-2006, 10:53 AM
The solenoid on the side of the manifold allows engine vacuum to pull fresh air into the canister, pulling the trapped HC vapors from the charcoal. That is only activated under certain engine operating conditions. The pressure in the tank is "controlled" by the evaporative emissions control valve located between the tank and the canister. The canister is open to atmospheric pressure.
When the fuel tank is venting, the spring loaded valve between the tank and the canister opens and the vapor flows out of the tank, through the canister, where the HC's are absorbed, then the cleaned vent flows out of the canister. When the PCM opens the purge solenoid, air is pulled in through nozzle #2 on the canister (reference Shoebox's diagram), picks up the vapor from the canister, and it flows to the intake manifold.
Injuneer is offline
Old 10-17-2006, 11:50 AM
WS Sick's Avatar
I see, so the canister is the true vent and the manifold vacuume is there to dispence the waste (harmful fumes) from the canister.
WS Sick is offline
Magenta_Hearts
03-22-2015 03:36 PM
Magenta_Hearts
03-05-2015 07:01 AM
canbaufo
02-24-2015 10:27 AM
Deadbolt24
01-19-2015 01:29 PM
blac94Z
11-24-2014 07:12 PM
Quick Reply: Gas Tank Building Up Pressure
