Disable automatic headlights (Resistor)
Old 05-27-2008, 11:45 AM
  #31
thunderace31's Avatar
Originally Posted by Lt1t56
It worked on my '97
So the sensor is behinde the radio??
thunderace31 is offline
Old 05-27-2008, 01:49 PM
  #32
Thanks guys just went out and did this I just added some soder between the a-b spots no wire needed No more auto lights and no more daytime running lights
Old 05-28-2008, 09:01 PM
  #33
Billy Biker's Avatar
Originally Posted by Maximum Bob
Okay I'm curious, just what is it about Daytime Running Lights & Automatic Headlights that bothers you people SO MUCH that you have to go out of your way to disable them?
My 95 formula doesn't have any automatic or always on headlights thank god...but my wifes pontiac does. Every 50k friggin miles you gotta replace the hard to reach pita headlight low beams/tailights cause they burn out. I've never had to replace headlights in any other vehicle I've ever owned...including my formula which is still running the original headlights. I know the DRL's are supposed to make you more visible..but if the lights are aways gonna be on at least make them last awhile As much as my wife has to drive I'm constantly replacing something on her car....and everythings a pain to get to on it
Billy Biker is offline
Old 05-29-2008, 06:53 AM
  #34
LOW-LIFE's Avatar
neither of my 2 96's had the light sensor or auto lights.
LOW-LIFE is offline
Old 02-16-2009, 11:34 PM
  #35
02SS35thCAMARO's Avatar
I have a 2002 Chev SS camaro 35th anniversary edition....
just bought XENON HID lights and they're causing a 'clicking' noise when they go on.
From what I am reading, it is the automatic on headlights that needs to be disabled to fix
this problem, but I cannot find a 'HOW TO DISABLE' sheet anywhere. Does anyone know
where or how I can disable my automatic headlight feature??
02SS35thCAMARO is offline
Old 02-17-2009, 01:13 AM
  #36
Oxygen454's Avatar
On top of the camaro's dash, there is a an alarm LED light (if alarm equipped) and a hole beside it. When you remove the cover in the dash, there is a sensor. If you remove the sensor and replace it with a resistor, the lights will always think it is bright ooutside and not turn on unless you manually turn them on. My camaro is modified to work this way. Im not sure if your year of camaro has the same setup but Im pretty sure it does. Should be near center of the dash (top side).
Edit** This year looks different but I believe the sensor is near the LED light on the right in this pic
http://www.zorly.com/images_camaro/g...aro%20dash.jpg
Oxygen454 is offline
Old 05-24-2010, 07:31 PM
  #37
Chevycrew's Avatar
My 99 ss vert has the light sensor just to the passenger side of the alarm LED.
Chevycrew is offline
Old 06-28-2010, 12:27 AM
  #38
Chevycrew's Avatar
I bypassed my automatic headlights with a relay and an additional fog lamp switch. When the switch is in the on position, the led is on, and relay is in the open position. This shows that the automatic headlight function is active.
Then I wired the relay into the a and b terminals in the smaller connector on the DRL module. When the switch is in the off position, it powers the relay to make a connection between the a and b terminals, effectively disabling the auto headlamps and daytime running lamps.
This is an advanced way of just connecting the two wires together at the ambient light sensor.
WobblySausage
10-07-2015 10:09 AM
68camaroboltz
10-05-2015 01:46 PM
football4life
10-04-2015 07:48 AM
Hal Fisher
09-30-2015 09:03 PM
drt
09-27-2015 04:39 PM
Quick Reply: Disable automatic headlights (Resistor)
