Difference between the Z28 and SS?
I'm doing some research on Camaros, and I wanted to know all the differences between a Z28 and an SS?
So far I know the SS models have the ram air setup, rear spoiler and the SLP exhaust and suspension.
Anything else I'm missing?
the SS was practically ONLY appearance-related items....
you can order additional things for the SS, though.. such as center-mounted exhaust, Auburn differential (i think it was), and in 2002 (last year) you could get a performance upgrade.. which increased the car to 245HP, i believe.. it was basically a LID, and i think a catback, maybe one other thing or something, I don't know
Mine has:
Cold Air hood
Rear Decklid spoiler
16" ZR-1 style cast aluminum alloy wheels
16" BF Goodrich Comp T/A tires
2 OTL exhaust
Torsen Limited Slip Diff
Hurst Six speed short throw shifter
High flow exhaust manifolds.
Synthetic lube package: Synthetic oil, rear axel lube and semi-synthetic power steering fluid.
Oil cooler
SS emblems replaces Z28 tags.
2 numbered keychains and 1 numbered dash plaque.
The 17" rims and Bilstein suspension is only available on coupes and T-tops.
Cold Air hood
2 OTL exhaust
Oil cooler
Hope this isn't thread jacking, it's semi related...
If your planning on putting on a cold air system, and a higher flowing exhaust system (seems that this is what gives most SS's higher hp ratings) anyways, wouldnt a regular z28 be a good/cheaper platform to get about the same kind of power from?(minusing the appearance/cool factor of course)
I believe the LT1 Z28s and SSs had a bigger hp gap then the LS1 versions.
Originally posted by 96SSConv#2033
Mine has:
Mine has:
16"??? where did you get those. I've seen only one set of those ever.
17" only on coupe and t-top? I don't think so. SS has 17" on all models i've seen, including convertables.
16"x8.0" ZR-1 Style Cast Aluminum Alloy Wheels
The one page front and back brochure says 17" with a * that says "Convertible models retain stock Camaro Z28 suspension, receive 16" version of BFGoodrich Comp T/A tires and receive 16" x 8" ZR-1 styled cast aluminum alloy wheels."
If my scanner was working I would scan it for you.
Here is a link to the SLP website with the exact same rims that I have:
http://www.slponline.com/view_produc...&SHOWEMAIL=Off
I have a '96. '97 and newer may have had the upgraded suspension and bigger wheels.
When GM had more to do with the SS in 98, all SS's came with 17" wheels.
Also 96-97 SS's had a polished lip on the rim. I don't recall seeing anything from 98 on with that. Correct me if I am wrong.
