Did the window motor thermal bypass...OMG do they work better.
#16
Re: Did the window motor thermal bypass...OMG do they work better.
Wonderful write-up; please fix your picture links.
#17
#18
Originally Posted by Injuneer
I don't think they're "his" pictures... it is a copy and paste from an old post.
http://web.camaross.com/forums/showthread.php?t=145075
Here's the pictures:
#19
I just did this mod to my old original drivers side window motor which was having all of the mentioned problems....window motor would shut down while rolling up the window and then work again after a time...very slow...I had to help it close etc. This mod suddenly restored my power window to like new performance. BUT!!!!
The author mentioned that the AUTO down feature still works like its supposed to....NOT!!!
The auto down feature still works......but it used that thermal breaker system to sense when to stop trying to roll down the window. With this mod done..the window motor will NOT stop trying to go down until either A...it trips the breaker under the dash...or B...It burns out the motor. I think I am going to try to find a way to defeat the Auto down feature because I dont want someone else to get in my car and hit the down button on the window and then inadvertently burn out the motor or damage parts in the door or burn up the circuit breaker. This mod DID restore my power window to like new performance.....but it doesnt come without risks.
#21
This issue crossed my mind as well, I have yet to have any problems.
Im only speculating here, but it seems to me that the breaker will be fine doing its job cause thats what its for. It would be cake to replace the breaker and disconnect the auto down function if need be.
With respect to the relay mod, I would think the issue would be even worse cause the motor power is tied more straight to the battery rather than to the onboard window circuit, that is even if it is an issue.
Maybe someone with more experience can chime in on this.
#22
I am not tied "direct" to the battery. I have an inline fuse in the run from the battery. Though I never really seriously considered the thermal bypass method -it makes sense regarding the express down. I can hear the slight ticking of the relays when I engage the window - and when it reaches the bottom of the cycle it takes a second or two before that relay releases. So it does seem that the thermal circuit has it's purpose (beyond preventing entrapment, and being annoying). I don't know if I would feel comfortable with the breaker protecting the motor on every cycle. It's designed as a failsafe - not an everyday switching mechanism. I could be way off base - its just IMHO.
#23
Am I still off base here?
#24
I ran a new line through the firewall and to the battery - which is fused. Check out the link below and Kudos to djw for drawing the schematic. The window and relay power are now supplied by the new run.
http://web.camaross.com/forums/showt...t=window+relay
#26
Originally Posted by teke184
sooo...
the inside of my window motor looked nothing like those pics
oh well
oh well
I just desoldered it and soldered in a piece of 12 GA wire in its place. It works great but it was a brand new motor when i did it (about a week ago) so i dont know if it will hold up yet or slow down after a few months like the other motors i've used.
-Greg
#27
wow- not to raise a dead thread -
but was having symptoms of my motor dying.. finally today she quit- followed the directions in this thread and motor works better than ever- and on side note soon as window hits rubber bumper at bottom of door the auto-down shuts off. guess im lucky ??
#30
Originally Posted by MarcR94v6
What would be "dangerous" about this mod, as others have suggested? Won't the motor get really hot?
