converting our stock rack to a manual
if i disconect all the lines and just leave it that way will i be able to turn still ? should i plug the line holes or will that just trap air and cause it to not turn at all?
I think you might want to check into this a bit more. I've heard that you shouldn't do this type of thing. I asked around while wanting to remove my p/s belt and run it just without the belt. Sorry, that I don't have any specific to add, but I do think this warrants further investigation.
Anyway, you might want to do a little research. I'd hate to have no steering control while testing/racing at high speeds.
Ben
Ben
The easiest thing to do is remove the pump and belt and run a loop connecting the two ports on the stock rack. DO NOT just block them off.
I had this on my car for a while until I swapped in a Pinto rack. Even w/ a manny rack, the car is MUCH easier to turn that with a bypassed power rack. The turning ratio in the Pinto rack is much MUCH better than the factory power rack (12:1 vs. 18:1, IIRC).
ChrisFrez
02-15-2015 07:49 AM
07-04-2005 05:00 PM
