computer - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 08-27-2014, 07:29 PM   #1
computer
is it true the 98 computer has problems reading certain cams if the lsa is above 110
daewokr is offline   Reply With Quote
Old 08-28-2014, 07:56 AM   #2
Super Moderator
Re: computer
The PCM doesn't "read" the cam. It has to be tuned for the cam. Where you would probably get into a problem would be the misfire detection, where the PCM might have a problem with the "crank relearn" that helps it determine when a misfire is occurring.
See this writeup:
Crankshaft Position Sensor Learn Issues on Gen III Engines
Injuneer is offline   Reply With Quote
Old 08-29-2014, 08:06 PM   #3
Re: computer
is it true a 2002 pcm will solve the cam issue? and if so where would I get one?
Reply
Thread Thread Starter Forum Replies Last Post
1994 Camaro lt1 frankrizz LT1 Based Engine Tech 1 09-23-2015 05:33 PM
1994 Camaro lt1 frankrizz 2010 - 2015 Camaro Technical Discussion 1 09-23-2015 05:21 PM
Computer Stolen fireside286 LT1 Based Engine Tech 4 09-15-2015 11:11 PM
97 LT1 EVAP Purge Solenoid Pressure Relief Plug Blowing Out 350350 Fuel and Ignition 14 08-11-2015 01:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
