this common with 10 bolts ???
Originally posted by coogsLS1
how much do you have in there? From what I have heard it is fairly common on 10 bolts.
Was it like very fine metal shavings (like what you find on the engine oil pan drain plug), or actual "chunks" of metal the size of BB's?? Fine metal shavings are normal, and may even appear almost like a solid piece if it's collected together for awhile, but if you got actual metal chunks, you may want to take a closer inspection and make sure there aren't any broken or chipped gear teeth inside.
carguyshu
01-22-2017 11:19 AM
