code 22
#62
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
Re: code 22
The ones at Harbor freight are cheap (~$6) and fairly good except for the test leads. If you buy one, use your old leads instead. if that is the case.
#68
Prominent Member
Re: code 22
The voltage measurement looks better with the new battery, but I still don't trust the ohms readings. The coolant temp sensor should read about 7000 ohms (or 7 kohms): 4th Gen LT1 F-body Tech Articles
Was the 4.4 ohms reading possibly a 4.4 kohms reading of the tps?
It's possible the meter may have damage that affects the ohmmeter reading circuit.
#70
Prominent Member
Re: code 22
Looks like the meter is bad when measuring resistance.
Honestly, I would order the cheapest TPS I could fine just to try it out. I know the good Delco ones cost about $50 but you can get Chinese-made ones for about $10. If it works, then you could opt for the better one.
#72
Prominent Member
Re: code 22
for reference:
Throttle Position Sensor TH47 Chevrolet Cadillac Buick GMC Pontiac Oldsmobile | eBay
also Rockauto has all prices from cheap to expensive
#74
Prominent Member
Re: code 22
Are you saying now that the starter doesn't work? Check all the fuses; you may have blown one changing the tps.
Let's keep the conversation going in here because we lose continuity via email. Just give me an email to let me know you made a new post here.
#75
Re: code 22
Ok...and idk if the starter is out I did notice that my radio is not on either so I have checked all the fuses under the hood an now moving to the one next to the door....
