Clutch Anticipate Switch after A4 to M5 Conversion - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 02-01-2014, 11:56 AM   #1
I need help with the PCM pinouts. My car is a 2001 Camaro and I did a conversion from an A4 to M5. Everything works fine, the only problem is the Clutch Anticipate Switch is not put in and my Cruise Control does not work, I also get a P0704 DTC code.
I know how the wiring for the switch goes but my question is the following:
From the clutch anticipate switch goes a GRY wire to the PCM Blue connector Pin #32. Now, do A4 Camaros come from the factory with a wire in that PIN and where does it go or do I have to put in a whole new wire?
And if a car is converted from an A4 to an M5, does it need the PCM Blue connector PIN# 33, which goes to the TCC Brake Switch, which is also used for Cruise Control functions?
If PIN# 33 is not needed for a manual car, can I just switch it to PIN# 32 and use that same wire to connect to the Clutch Anticipate Switch since its right next to the brake pedal and the TCC Brake Switch?
GusarskiSS is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Selling all my parts- built lt1 t56, full bmr, tons of LS stuff, QTP LS headers, etc carguyshu Parts For Sale 20 Yesterday 12:19 PM
No Reverse 2001 SS Beave2780 Drivetrain 3 07-07-2015 07:36 AM
96 SS no longer an LT1 FS Jasonz28camaro West South Central 2 06-07-2015 10:12 PM
Love my Z28 but............ timmy39120 New Member Introduction 4 05-02-2015 06:12 PM
LT1 T56 Clutch/PP/TOB and Flywheel HectorM52 Parts For Sale 0 01-31-2015 12:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
