Changing Foglight Bulb in 1992 Camaro Z28 : HOW? - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 10-16-2013, 04:36 AM   #1
So today I tried to change the foglight bulb myself and I was shocked that it's not easy!
I tried from the front reaching my hand thru the grill thru the foglight opening and then realized I needed to be double jointed to curl my wrist backwards to grab and twist the socket.
I then used two hands one on each side and used a finger on each side of the socket but then you have the button you have to press at the same time while turning so that didn't help.
In fact I nearly cut my wrists getting my hands BACK out.
So I tried from behind.. Put it on a lift and thought I could just reach under.. Course that didn't work as the Baffle is completely covering access.
Removed the deflector to be able to get more room to reach my arm thru the two ducts themselves as your shoulder hits it. It allowed SOME more room but still you are completely blind.
Mechanic was watching and took over and he cursed (under his breath) the whole time ending up taking 30 mins to do this!
He was stumped and all he could do was do the same thing as me and reach thru the ducting under the car behind the foglights themselves. This means your entire arm is inside and can barely reach inside to the end and then have to twist the socket.
Was a REAL PITA!!!
I've looked in Chilton (while says "foglamps" in the index for 6-35, there is infact NO mention of foglights in the manual; just headlights). And Hayes doesn't mention it either.
Googles results with nothing except a IROC-Z video from 1aauto except for the fact that ALL trim under the car was removed..
camarosource is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
94 camaro z28 coolant temp sensor in head 2 wire or 1 wire? Brandon Wittmer General 1967-2002 F-Body Tech 3 12-03-2014 10:28 PM
Seriously. Time for a board upgrade dudes. grendal Site Help and Suggestions 28 04-15-2010 06:20 PM
Aftermarket CD Deck with stock Bose Speaker/Amp system? CamaroHeed Car Audio and Electronics 12 11-29-2002 02:28 PM
Orion XTR dual voice coils 12" sub. Any good??? 2000silverz28 Car Audio and Electronics 5 07-20-2002 07:14 AM
Rename the show and shine forum dreamer1q Site Help and Suggestions 4 07-08-2002 09:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
